Project BEAST build
The Beast
Has thanked: 25 times
Project BEAST build
Post by The Beast » Thu Feb 13, 2020 10:30 am
Hello all,
This is my first thread so this is going to be fun.
I have a 1978 SE6A OD.
It was restored from the ground up and has had a lot of upgrades done as it was being prepped for hill climbs.
I now have it and would like to continue that venture but for it to also be a daily as I really enjoy driving it everywhere.
So I will ask questions about performance but it will always need to be reliable as it is being built as a daily first and foremost. If I do decide to get involved in hill climbs then I will be doing it just for the fun of it (so he says).
Thank you for all your help and advise that I have already received from some of you and for the advise still to come.
The Beast
Project BEAST build
Post by The Beast » Thu Feb 13, 2020 10:31 am
Does anyone have advice on oil coolers for these as I will be relocating the oil filter so I might as well?
Has thanked: 100 times
Been thanked: 796 times
Project BEAST build
Post by philhoward » Thu Feb 13, 2020 11:11 am
Unless doing circuit racing with a long time at full chat, I doubt you'll need a cooler?
If you do that way, I'd go with Mocal every time personally.
The Beast
Project BEAST build
Post by The Beast » Thu Feb 13, 2020 11:31 am
Perfect, thank you.
I was thinking about long trips and then being stuck in traffic in the summer. Only because I have read a few of the Essex v6s overheating but then again mine has better pipping and an upgraded electric fan.
I was thinking of taking her to the ring in Germany so I guess I just want to be extra carful.
The Beast
Project BEAST build
Are there anything that anyone would recommend doing just to make sure I cover all angles?
Thanks in advance.
The Beast
Project BEAST build
Post by The Beast » Thu Feb 13, 2020 12:26 pm
Been thanked: 87 times
Project BEAST build
Post by Old and Slow » Thu Feb 13, 2020 6:03 pm
IIRC one question you asked earlier was about electronic ignition.
An acquaintance has an AC Ace with the straight six engine, same as mine, and he's running a Boyer Bransden system as this keeps the points (for originality) but acts as a current booster, so the current through the points is kept very low.
http://boyerbransden.com/
One day perhaps, I'll fit this, but in general I think KISS is probably best.
The Beast
Project BEAST build
Post by The Beast » Fri Feb 14, 2020 8:49 am
Thank you for this, very helpful. I am going to look into it more and see how I get on because as I inspect this car and learn more about it, the more I realise that it has had a lot of work done and things upgraded.
The Beast
Project BEAST build
Post by The Beast » Tue Feb 18, 2020 4:09 pm
Hi all,
Does anyone know or have an idea to why the springs under my rocker cover are red. I know that it is said to have a race engine in there but I know very little else about it. Any recommendations on where to take her to have a proper check over to see just what is in there and what has been done?
I am in Croydon London so if there is a local place, that would be amazing but if not then I just need to know where to take it, that can be trusted.
Thanks in advance.
David Tew
Has thanked: 24 times
Project BEAST build
Post by David Tew » Tue Feb 18, 2020 5:35 pm
If you have single springs with a red flash I suspect they're uprated as standard springs have a white flash. The difference is in the max revs, approximately 6,000 for standard and 7,000 for uprated.
Double springs are rated to approx 7,500 and 8,000.
The Beast
Project BEAST build
Post by The Beast » Wed Feb 19, 2020 9:43 am
Thanks David, very helpful. Is there anything else that I can look for to get an idea of what has been done without stripping the engine apart?
Been thanked: 70 times
Project BEAST build
Post by Nick » Wed Feb 19, 2020 10:17 am
The old advice is to replace mechanical with electrical
Fan, Ignition and fuel pump.
If you have the rocker covers off you can check cam lift and possibly duration, also presumably it has a steel/alloy cam gear?
David Tew
Project BEAST build
Post by David Tew » Wed Feb 19, 2020 10:33 am
It's very difficult to see exactly what internal changes might have been done. Do you have any paperwork from the PO who did the work?
You still have the DGAS carb so I wouldn't think too much radical work has been done (unless it's been bored etc! ).
It is important to check that the fibre cam gear has been changed to alloy or steel. You can do this through the old fuel pump fitting (oil catch pipe in your case). Personally, I'd be inclined to return the oil catch system back to standard. You don't really need to use catch tanks unless you're considering competition. Also run through the wiring and remove any dodgy crimps, unnecessary cabling, etc..
KISS is always a good acronym to follow as mods can hide other problems. :wink:
EDIT - Nick, you're just too quick! :lol:
The Beast
Project BEAST build
Post by The Beast » Wed Feb 19, 2020 11:22 am
Thanks Nick.
The fan, Ignition and fuel pump have all been upgraded but I am still to find out what the make and models are.
The Beast
Project BEAST build
Post by The Beast » Wed Feb 19, 2020 11:41 am
Thank you so much, I will be checking this weekend, fingers crossed that the gears have already been done.
I completely agree about KISS, I intend on redoing the entire wiring system using toggle switches, keeping everything on a simply circuit. I am trying to find the details of the engine. I think I have the number of the fella that did the restoration, sourced and fitted the race engine.
The paperwork says that it is a race engine but not much else, it was just typed up so I just thought that he might have just said that because its painted red but when I drove it properly for the first time, it felt different.
I am trying to find someone locally to inspect it and to do some work, so if anyone knows anyone in the south that they would recommend, that would be great.
