Overdrive breather
dand
Overdrive breather
Post by dand » Sun Aug 11, 2019 7:51 am
We've been refurbing the gearbox on the coupe and as we're about to refit the overdrive unit to it noticed that the breather on the top of the overdrive is very wobbly and loose fitting.
Is this how it's supposed to be? Seems a good potential source source of oil leaks given the pressures in the overdrive?
Been thanked: 172 times
Overdrive breather
Post by gtcse8 » Sun Aug 11, 2019 8:47 am
Which OD unit is it?.
I have some New breather inserts for Laycock OD.
Picture would be good?.
dand
Overdrive breather
Post by dand » Sun Aug 11, 2019 11:49 am
Here you go. I think it's a standard Laycock unit from 1967. It's in a 3.0 V6 coupe.
OD breather 1.jpg (204.84 KiB) Viewed 530 times
OD breather 2.jpg (217.41 KiB) Viewed 530 times
Has thanked: 157 times
Been thanked: 1078 times
Overdrive breather
Post by scimjim » Sun Aug 11, 2019 1:23 pm
Looked at a spare box and it doesn’t move. I don’t think it matters too much if it’s just the cap (which is there to stop fluid/debris ingress) - crimp the edge a bit to hold it in place?
Or is the actual vent loose?
dand
Overdrive breather
Post by dand » Sun Aug 11, 2019 3:16 pm
It's the actual event that's loose. Seems to be held in by a spring that allows a fair bit of wobble.
Overdrive breather
Post by gtcse8 » Sun Aug 11, 2019 4:38 pm
Hi
Have found my New vents and they are the later press in type.
Don`t know if they will fit your unit.
dand
Overdrive breather
Post by dand » Sun Aug 11, 2019 8:36 pm
I think those are a different design. But let me remove it from the O/D casing and I'll see how the whole thing looks.
