Float height
GTC Ian
Float height
Post by GTC Ian » Fri Jul 19, 2019 10:09 am
Just re fitting the carb (38 DGMS)together, but have conficting float heights. I have the plastic floats. Anyone know the correct heights? I have set the float to 35mm & 51mm.
Members since 1984
Has thanked: 157 times
Been thanked: 1078 times
Float height
Post by scimjim » Fri Jul 19, 2019 10:22 am
plastic float 34/44, brass float 41/51 IIRC.
GTC Ian
Float height
Post by GTC Ian » Fri Jul 19, 2019 10:24 am
Thanks Jim. That fits in with 10mm travel of the float required
Members since 1984
Been thanked: 122 times
Float height
Post by ScimmyMike » Fri Jul 19, 2019 10:25 am
Float height
Post by scimjim » Fri Jul 19, 2019 10:40 am
Hmm, my figures came from a Haynes manual IIRC, either Ford or the Weber Carbs one?
The low point isn’t as critical as the high point of course, as long as it’s totally shut the valve at 35mm (check by blowing into the inlet pipe).
GTC Ian
Float height
Post by GTC Ian » Fri Jul 19, 2019 10:45 am
Thats the diagram I found, along with others that had conflicting dimensions. Confusing isnt it!
Members since 1984
