Replacement carpets
KJF
Replacement carpets
Post by KJF » Sun Jul 07, 2019 5:50 pm
Does anyone have experience of the carpet kits from Car Hoods or Coverdale as I will be ordering a set very soon once I have checked the colour samples of Autumn Leaf and Ochre with chocolate/tan coloured interior.
Has anyone experience of any other suppliers?
Finally, do the club have any deals negotiated with either supplier?
Thanks in advance!
Been thanked: 283 times
Replacement carpets
Post by AJL Electronics » Sun Jul 07, 2019 6:18 pm
You will get far lower cost with little extra work by buying off the roll. Commercial carpet sets are all wrongly cut, but anyone who complains is told that nobody else has ever had a problem. Make of that what you will.
Been thanked: 123 times
Replacement carpets
Post by ScimmyMike » Mon Jul 08, 2019 10:01 pm
As Andy said, the kits aren't a great fit and suppliers go all ostrich when it's mentioned to them, probably less work to buy a kit then modify but as I found it's the bound edge bits that needed work then rebinding so I figured buy off the roll and DIY getting edges bound as required and save a fair bit of money so long as you have carpet to creat patterns from in the first place.
peter
Has thanked: 27 times
Replacement carpets
Post by peter » Tue Jul 09, 2019 8:34 am
About 2 years ago I bought the complete set from Coverdale. No complaints. Two weeks delivery. The price was reasonable.
Hope this helps.
Peter
Has thanked: 67 times
Been thanked: 200 times
Replacement carpets
Post by gtcse8 » Tue Jul 09, 2019 8:37 am
KJF what car are you doing up??.
The kits from coverdale for the SE6 and GTC are too complex and they even supplied sections for the fabric arm rests, go figure. :roll:
When I was full time with Reliants I tried to get a deal together for Scimitar owners but nothing came of it, then coverdale had a fire and lost the templates so I tried to get them to start from scratch with the Scimitars but the last Two sets I got from them were very fiddley to get to fit.
Is Gary Taylor from Manchester still out there?, he made a brilliant job on a few cars for me.
Mark Wilson. Garage sale everything must go. :cry: SE5a`s, GTC, SE6b`s, Triumph Daytona, Honda CB750 K7. Also on YouTube :wink: lookup V8 Chevy https://youtu.be/lbpvDGAMY6g https://youtu.be/7xTrbr0ETSA https://youtu.be/K7HfYVd5Flo
1969SE5
Replacement carpets
Post by 1969SE5 » Tue Jul 09, 2019 10:31 am
my Coverdale ones were shocking, some additional bits that I still have no idea where they go, and most needed a lot of trimming, pretty dissapointing, its not the cost of the carpet, its the time and the effort in trying to get them in, then to stand back and think, well its OK but not perfect.................
Has thanked: 106 times
Been thanked: 807 times
Replacement carpets
Post by philhoward » Tue Jul 09, 2019 10:36 am
Coverdale seem to think a 5 and a 5a have the same carpets which isn’t the case..and even then they aren’t a marvellous fit. That’s assuming you can figure out what to use where (and which bits you can modify).
Rev Light
Been thanked: 30 times
Replacement carpets
Post by Rev Light » Tue Jul 09, 2019 10:37 am
I suppose it depends if you have some old carpet to use as templates.....My car has no carpet in any of the foot wells, having long since rotted away.
SE5a 'Fancier'
GTC Ian
Replacement carpets
Post by GTC Ian » Tue Jul 09, 2019 10:40 am
So disappointed with my set. Just such a poor fit. I wouldnt recommend them to anyone. In hindsight I wish I got our local trimmer to make them.
Members since 1984
Has thanked: 167 times
Been thanked: 1175 times
Replacement carpets
Post by scimjim » Tue Jul 09, 2019 10:44 am
It does seem that the SE6 set (which they laughingly think is the same as a GTC) is worse than the 5 series. I managed to make a set fit my SE5 but it was particularly annoying having to cut bound edges. Their customer support is just non-existent.
Replacement carpets
Post by Roger Pennington » Tue Jul 09, 2019 12:26 pm
I can't speak for anything other than Se6a obviously, but it's worth noting that the original carpets didn't have bound edges, so if you end up making your own, without them, that's actually a more authentic option :)
KJF
Replacement carpets
Post by KJF » Fri Jul 12, 2019 12:04 am
Guys thanks for all your replies. I’ve decided to buy off the roll and cut myself getting any edges bound as required.
gtcse8, GTC chassis 305 is the car.
TrevorG
Has thanked: 35 times
Been thanked: 44 times
Replacement carpets
Post by TrevorG » Fri Jul 12, 2019 10:03 am
Hi, did mine a few months back and spent out on better quality carpet and underlay so that I didn't need to bind the edges and the carpet could be moulded into shape by stretching and pressing. Just take your time.....I found that heavy weights left overnight on an uncut footwell piece helped in getting the shape prior to cutting.
Don't use the originals as templates, more as a guide, as they distort as you pull them out if stuck down with glue or age!
You can also think about changing the footwell ply pieces at the same time as they are naff.
Good luck....it is rewarding knowing you've done it.
Eric2205
Replacement carpets
Post by Eric2205 » Fri Jul 12, 2019 11:07 am
Hello everyone
I do not need to change the mats of my Se5a so I can not say.
But a few years ago I bought at Coverdale a Carpet Set and Self Adhesive Underfelt for my Wolseley 1100
It was good quality and I had no particular problem
scimmy_man
Been thanked: 43 times
Replacement carpets
Post by scimmy_man » Fri Jul 12, 2019 11:25 am
Hello everyone
yea but Coverdale have probably physically SEEN an Austin 1100.
from the carpets I have seen for Scimitars, they have worked off an out of focus photo,
