V6 essex timing gear
rebel alliance
Been thanked: 62 times
Post by rebel alliance » Wed Apr 10, 2019 4:02 pm
Nylon ☺
halfpenny
Post by halfpenny » Wed Apr 10, 2019 4:21 pm
An aluminium gear has a better chance of bedding to an existing steel crank gear. I went this route, and the initial whine has gone after 5k. Slightly mismatched steel gears will not bed in any sensible time frame, so changing them as a new matched pair is probably the best way of obviating whine.
RodH
Post by RodH » Wed Apr 10, 2019 8:29 pm
turboscim wrote:
Wed Apr 10, 2019 7:56 am
Car s o s was Ric Wood not J. W.
Sorry, My mistake.
82 GTC, 84 SE6b, 77 SE6a,
Saab C900 T16S Vert, 9000 2.3FPT lpg, C900i Vert.
Penfold13
Post by Penfold13 » Wed Apr 10, 2019 9:16 pm
Sarecen wrote:
Wed Apr 10, 2019 12:17 pm
New gear kit sourced and on its way
Hello,
Just took the fuel pump off and looked at the timing gear and it looks like a fibre gear. Fibre’s clearly a no-no, steel seems to have some issues, so what’s the drawback with alloy?
What gear type did you get Dave and where from?
Thanks,
Chris
‘72 SE5A
Nigel Clark
Been thanked: 47 times
Post by Nigel Clark » Wed Apr 10, 2019 9:25 pm
I fitted an alloy camshaft timing gear from Burton on my SE6A nearly 4 years ago. This is just the camshaft gear and runs with the original steel gear on the crank.
It was a little noisy at first but quietened down after a few hundred miles. Since then, it's covered almost 15k miles with no problems.
Nigel
Penfold13
Post by Penfold13 » Wed Apr 10, 2019 9:45 pm
Thanks Nigel, assuming this one:
https://www.burtonpower.com/steel-camsh ... fv419.html
Is it worth going all out for the QRG kit:
SE4a on Alloy timing gear c/w crank gear and gasket/seal kit £285.00
‘72 SE5A
Nigel Clark
Post by Nigel Clark » Wed Apr 10, 2019 9:53 pm
No, not the Burton steel gear. They also have an alloy version that runs quieter but for some reason it's not easy to find on their website.
Try phoning and asking for their alloy Essex timing gear, it will be quieter than steel and plenty strong enough for road use.
Nigel
Stoddy
Post by Stoddy » Wed Apr 10, 2019 10:16 pm
Having finally got myself a GTE after a long winter search I'm wanting to check the timing gear on my new purchase. Is it necessary to remove the fuel lines to the fuel pump before removing it or is it simply undo the bolts and move it to one side to inspect?
Alan
Has thanked: 146 times
Been thanked: 1026 times
Post by scimjim » Wed Apr 10, 2019 10:35 pm
That depends how long your fuel lines are :D
The fuel pump arm is quite long, so you will need quite a bit of slack if you don’t want to disconnect the fuel line?
Has thanked: 161 times
Been thanked: 543 times
Post by Roger Pennington » Thu Apr 11, 2019 12:09 pm
I think from memory, I just managed to get away without disconnecting the fuel pipes, bearing in mind that the metal feed pipe at the front of the engine is bolted to the front cover bolts, you gain a bit more slack there. However the total length of pipe will still be the deciding factor.
Post by Roger Pennington » Thu Apr 11, 2019 12:12 pm
Bearing in mind that Ric Wood (and probably others) uses alloy ones in racing, I don't think there's any question mark over their strength :)
(in fact I was watching him racing his 3 litre Capri last weekend)
Stoddy
Post by Stoddy » Thu Apr 11, 2019 10:17 pm
Thanks had a better look this evening. My car has braided hoses fitted and it doesn't look like they will allow much movement so I think I will disconnect so I can remove the pump straight from its mount.
Thanks for your help.
Post by scimjim » Thu Apr 11, 2019 10:48 pm
Unless they’re PTFE lined, I’d replace the braided lines while you’re there.
Penfold13
Post by Penfold13 » Sun Apr 14, 2019 9:15 pm
Sorry for the slow response. For the extra effort, I’d remove the lines and take the opportunity to have a quick look at the fuel pump too.
‘72 SE5A
Stoddy
Post by Stoddy » Mon Apr 15, 2019 9:09 pm
Thanks for your advice. I'm even slower at getting back! I took the pump off this evening and what I'm seeing through the hole is a steel gear with gold coloured teeth. Do I take it from what I've seen that I have fibre timing gear?
I'll check the receipts I got with the car to see if the hoses are PTFE spec. Re the fuel pump, what am I looking for?
Alan
