Coolant temperature sensor: thread size and pitch?
hermeticist
Has thanked: 28 times
Post by hermeticist » Fri Mar 29, 2019 10:34 pm
I think my thread is damaged on the coolant temperature sensor hole (For the temperature gauge). Does anyone know the correct pitch and thread size (online sources state m12 x 1.25, which is clearly rubbish...)?
It looks like 15mm but that seems a bit of an odd size...
Thanks!
Been thanked: 135 times
Post by Oaksey » Fri Mar 29, 2019 10:48 pm
Buy one from the suppliers. They're a special resistance IIRC and most make the gauge read wrong
1973 Beige Se5a Overdrive
2005 Honda S2000
hermeticist
Post by hermeticist » Fri Mar 29, 2019 10:51 pm
I bought a new sensor from QRG, it's the hole it goes in that is being naughty... :)
hermeticist
Post by hermeticist » Fri Mar 29, 2019 10:53 pm
I was going to try a quick recut of the threads...
Has thanked: 64 times
Been thanked: 632 times
Post by philhoward » Sat Mar 30, 2019 5:36 am
1/8”NPT?
Has thanked: 140 times
Been thanked: 998 times
Post by scimjim » Sat Mar 30, 2019 7:58 am
This is a Ti IIRC?
Are you sure you’re looking at the gauge sensor and not one of the other two coolant temp sensors? 15mm sounds more like one of the others.
hermeticist
Post by hermeticist » Sat Mar 30, 2019 1:36 pm
Yes Jim, sorry 1800ti. I re-measured the sensor (definitely gauge: single wire) this morning, and it's approximately 16 x 1.5 (max thread width of original part is 15.84 and new part is 15.76). Measuring the pitch, old part: 9.18mm divided by 6 threads = 1.53 New part: 8.83mm divided by 6 threads = 1.47
Shame I haven't got a thread measuring tool but that's the closest I can get. Last night I could have sworn it was 1.25..!
Unfortunately, the fastening shops in Plymouth are closed all weekend, so I'll have to wait :( I'll get a tap on Monday and clean it out...
Going back to what Josh said: I understood that I still needed to fit a resistor (difference between Nissan sensor and Austin Rover clocks)? But I was going to wait until I'd tested things...
Post by scimjim » Sat Mar 30, 2019 2:18 pm
The one hidden under the stat? I’m amazed it’s 15mm. Anyway, standard Nissan part with the resistor added by Reliant.
Been thanked: 358 times
Post by peter freeman » Sat Mar 30, 2019 2:22 pm
33 ohm resistor is required if my memory is not playing tricks
hermeticist
Post by hermeticist » Sat Mar 30, 2019 3:13 pm
Yes, I have a couple of the correct resistors, thank you Peter.
I know, it seems mad! It takes a 17mm socket to remove it:
hermeticist
Post by hermeticist » Tue Apr 02, 2019 10:16 pm
A quick follow up in case anyone else has an issue...
When removing or fitting, the easiest way (with coolant hoses in place) is to use a long 17mm socket. However, this means the socket (unless it has a very thin wall) is angled and can crossthread the housing and sensor. I always try and finger tighten things until it is definitely on the the threads but if the housing threads are already damaged then you may have an issue getting a tap in there.
I took the sensor into a local fittings supplier, who told me it was actually a bsp thread. So I went to a hydraulic supplier who sold me a blanking plug but in M16 fine (1.5 pitch), he said it wasn't bsp... Anyway, I then bought a machine screw and nut in M16 1.5 but this was too large to fit in straight, due to the tight confines of the sensor area. I used the blanking plug to clean up the threads (being alloy it is soft enough that, if used carefully, a steel thread will act as a cheap substitute for a tap if used VERY carefully - don't do this at home :) ).
I used the nut to clean up the sensor thread and all fitted well...
I hope this helps but don't beat me for not using the appropriate tap...
hermeticist
Post by hermeticist » Tue Apr 02, 2019 10:17 pm
Oh, apparently there are also two different sensors for early and late engines (this is according to Nigel at QRG), so do check the thread!
