Unleaded conversion.Recommendation
Sarecen
Post by Sarecen » Thu Mar 07, 2019 2:23 pm
Hi All
Have the heads off my 3.o Essex and was wondering if anyone has a contact in the Peterborough/Cambridge area that could carry out this work.
1977 GTE 6a
Thanks in advance
Sarecen
Has thanked: 50 times
Been thanked: 599 times
Post by philhoward » Thu Mar 07, 2019 2:35 pm
GTC Ian might be able to recommend someone local but there seems to be more reports of valve seats falling out than valve seat recession from running on unleaded fuel... The Essex doesn't really seem to suffer that much (I'm not saying it doesn't) - the cost of converting buys an awful lot of additive as well.
Been thanked: 351 times
Post by peter freeman » Thu Mar 07, 2019 3:13 pm
It being a relatively low revving engine makes it less prone to valve seat regression. Our 5A had 251,000 miles on the clock when we sold it, it had done 70,000 miles ( 20,000 on that engine ) when I bought it - never used any additive in all that time - total mileage on the engine without additive or modification 201,000 miles. Only fit hard seats if the current ones are worn away is my advice.
Sarecen
Post by Sarecen » Thu Mar 07, 2019 5:05 pm
Thanks for you replies.
Spoke to an engine specialist and he said the same, if it aint broke, dont fix it :D :D
Valve seats are really good, but need regrinding with fine paste. next job in the garage then !
Thanks again,all.
Sarecen
TrevorG
Post by TrevorG » Sun Jun 02, 2019 5:14 pm
Sorry to resurrect the unleaded conversion discussion especially as I wasn't going to convert, but I've been removing the valve gear today to lap the valves in and put new seals in place and noticed that feb's heads have got exhaust seat inserts. I'm assuming then, that she's been converted, or did the original heads in 79 have inserts fitted? I cannot remember robin rew doing this although he gas flowed the heads as part of the upgrades in 87, so he might have! Any other clues?
