battery cut off relay
Has thanked: 69 times
Been thanked: 663 times
Post by philhoward » Sun Mar 03, 2019 6:52 pm
willholderogri wrote:
Sun Mar 03, 2019 6:12 pm
Its a good idea but it needs to be in the live feed
Doesn’t make any difference electrically.
Has thanked: 173 times
Been thanked: 30 times
Post by willholderogri » Mon Mar 04, 2019 12:06 pm
I know but its always good practice to switch the live side
rebel alliance
Been thanked: 62 times
Post by rebel alliance » Mon Mar 04, 2019 12:50 pm
I have the extra earth lead on order, i was going to put the relay down low near the front ..post some pics when i'm done
paintman
Post by paintman » Fri Mar 15, 2019 11:52 pm
Be an idea on a car that's used infrequently to stop any battery drain issues & easier than having to lift the bonnet to use a rally type switch.
It doesn't make any difference if it's in the battery negative lead.
Any chance of a link to the ebay seller you used please?
Don't operate the switch whilst the engine is running, your alternator won't like it.
rebel alliance
Post by rebel alliance » Sat Mar 16, 2019 12:09 am
The one i got turned out to be unsuitable ..The problem with the starter type is after about an hour the operating coil gets very hot..so i'm after a 500 Amp normally closed type so the operating coil would only be used to cut power in the event of a short or fire in the loom...not found one as yet
Post by philhoward » Sat Mar 16, 2019 6:14 am
I doubt you will find one like that.
What you can get is:
https://www.demon-tweeks.com/uk/brise-e ... riev200-h/
Or:
https://www.demon-tweeks.com/uk/cartek- ... kck-bt-02/
Made for the job of being turned on and off by means of a remote push button/switch.
rebel alliance
Post by rebel alliance » Sat Mar 16, 2019 7:08 am
I could buy another scimitar for that money...keep looking Phil
Post by philhoward » Sat Mar 16, 2019 7:14 am
I’m not the one after a solution, Justin.. :wink:
derekoss
Been thanked: 20 times
Post by derekoss » Sat Mar 16, 2019 9:04 am
Bowden cable operate a normal battery switch. You could pull a knob as fast as throw a switch.
Derek
rebel alliance
Post by rebel alliance » Sat Mar 16, 2019 9:39 am
Good idea , i can make that work
Has thanked: 146 times
Been thanked: 1030 times
Post by scimjim » Sat Mar 16, 2019 9:58 am
FIA spec battery switch (which come with alternator protection and remote pull if you need) don’t bother with cheap ones, the contacts will corrode/arc and leave you stranded one day.
Post by willholderogri » Sat Mar 16, 2019 10:49 am
I'm with Derek I have a Bowden cable set up for mine
Ambient69
Post by Ambient69 » Sat Mar 16, 2019 3:17 pm
Batterybrain is another type worth considering.
