Upgrading to discs all round
Has thanked: 136 times
Been thanked: 968 times
Post by scimjim » Sun Mar 03, 2019 5:23 pm
That’s exactly what we do to fit vented discs on the SS1 etc - spacers and an extra set of o-rings with longer bolts and the metro turbo fitting kit (they had vented as standard).
Been thanked: 116 times
Post by gtcse8 » Sun Mar 03, 2019 5:52 pm
Are you happy with your New set Jim?.
Pictures please?
Rest of the parts are in transit.
Ethanol
Post by Ethanol » Mon Mar 04, 2019 6:00 am
Does it work with Lockheed callipers though?
When you increase the compression of any engine you make it more thermodynamically efficient, that makes it more powerful.
Has thanked: 156 times
Post by willholderogri » Mon Mar 04, 2019 7:53 am
they bolt together so no reason why not, but the vented discs will only improve the car if your giving it hell
Post by gtcse8 » Mon Mar 04, 2019 9:09 am
Easiest and cheapest upgrade is Drilled and Grooved disc. :idea:
Readily available, I think I have a few sets left from the last batch I sourced.
Mick G has them on his Middlebridge along with 3 pot Girlings, which use a bigger pad, and has used them in anger at motorway speeds :o
turboscim
Post by turboscim » Mon Mar 04, 2019 9:21 am
I have vented wilwoods with dual circuit remote servo that will cope with anything I have done.
The most important factor is pad make and material, get the heat range for a particular use.
Ethanol
Post by Ethanol » Mon Mar 04, 2019 1:35 pm
I think uprated brakes are essential if I fit the ethanol engine, I've also got a Kent fast road cam for it so, not only will the emissions be much better ethanol is carbon negative
Post by scimjim » Mon Mar 04, 2019 1:48 pm
For a road car I don’t think updated brakes are essential at all - BHP doesn’t determine braking requirements, it’s how you’re using it. The small sports brakes are known for fade after heavy use on track (or mountain passes :D ) - the GTE brakes are pretty good as standard and simply fitting vented won’t improve the braking power, just the heat dissipation.
Has thanked: 144 times
Been thanked: 525 times
Post by Roger Pennington » Mon Mar 04, 2019 2:47 pm
Put simply,
For more braking power, fit larger diameter discs/larger area pads
For more braking endurance (ie heat dissipation) fit vented discs.
David Tew
Post by David Tew » Mon Mar 04, 2019 2:50 pm
If you ignore any CO2 produced during the creation of ethanol, it can be considered carbon negative until it is burnt when it becomes carbon neutral as you're then producing the same level of CO2 as that absorbed by the plant from which it is made. Still better than petrol, of course.
In truth, the only truly carbon neutral fuels are wind, solar, tidal and wave as no CO2 conversion or emission is involved whatsoever.
A wave-powered Scimitar, now there's a thought! :)
Post by scimjim » Mon Mar 04, 2019 2:58 pm
You can’t ignore co2 produced during creation though (or impact on global economies from changing farming practices)
And none of those fuels are carbon neutral (at point of use) once you’ve built the machines to collect, convert, transfer and store it :P
https://twitter.com/BBCArchive/status/1 ... 77697?s=20
AntC
Post by AntC » Mon Mar 04, 2019 3:09 pm
Great Link!
Ant
Scimitars owned:
2018 - 19 SE5 SCV 748 G
2001 - 13 SE4b - TMA 911 J
1971 - 76 SE5 CYB 435 J
David Tew
Post by David Tew » Mon Mar 04, 2019 3:31 pm
You're right, of course, Jim. I was trying to make the point that most carbon neutral/negative claims are very dubious. :wink:
However, wind, solar, tidal and wave are carbon neutral in their natural state, it's when us humans get involved that things are spoilt!
I still fancy a wave-powered Scimitar. Must be better than a coal-powered Crapi. Fancy a challenge? 😄
Post by scimjim » Mon Mar 04, 2019 4:19 pm
Isn’t petrol carbon neutral in its natural state? :D
I fancy an electric Scimitar but that has some of the worst carbon footprint claims of all alternative fuels :P
https://www.carandclassic.co.uk/car/C991770 :W
David Tew
Post by David Tew » Mon Mar 04, 2019 5:10 pm
Isn't petrol carbon neutral in its natural state? :D
As unextracted crude oil, yes. However, once it's been refined ..... :-P
Anyway, I'll stick to my ancient, polluting, petrol-powered, torquey Essex for my Scimitar kick. My eco-nod is my hybrid daily (no, not a Prius!), the battery of which produces far more CO2 during manufacture/recycling than the hybrid technology will ever save! :doh:
