Very lumpy when cold
Brucky
Post by Brucky » Thu Feb 28, 2019 8:15 pm
Hi gents,
I am after a bit of advice please on my Essex Coupe. Its a problem that’s got gradually worse and has built up over the past two months. On a cold start up if it’s left overnight it’s very lumpy for up to 1 minute now, like it’s only firing on one bank, rough as a badgers, sounds like a Massey Ferguson :) After about 1 minute of driving it smooths out very quickly in just a few seconds, then it runs perfectly. If I start it from hot it’s perfect, it will fire up perfectly no lumpiness. Any ideas would be greatly appreciated.
Thanks John.
Been thanked: 265 times
Post by AJL Electronics » Thu Feb 28, 2019 8:20 pm
Auto or manual choke?
Has thanked: 26 times
Been thanked: 113 times
Post by Coupe Racing » Thu Feb 28, 2019 8:21 pm
Possible gasket beginning to fail and seals when it warms up ?
Brucky
Post by Brucky » Thu Feb 28, 2019 8:26 pm
It’s a manual choke, would 1 min be quick enough to warm the seals.
Post by AJL Electronics » Thu Feb 28, 2019 8:41 pm
Possibly not enough or too much choke for the ambient temperature. Once it fires, try playing with the choke position to see if things improve.
Nigel Clark
Been thanked: 47 times
Post by Nigel Clark » Thu Feb 28, 2019 10:14 pm
My SE6A is quite lumpy on its auto choke for the first 1/4 mile or so from a stone cold start. After that it smooths out.
Different car, different engine and carbs but my Triumph GT6 with manual choke is fussy about how much choke it needs for the first 5 minutes from a cold start.
Maybe you just need to play with how much choke you give the engine. We soon forget that classic engines are not like modern EFi, which run perfectly from cold.
Nigel
Post by AJL Electronics » Thu Feb 28, 2019 10:34 pm
And again, if it is a conversion, you will not have the required fast idle speed. That will certainly make it feel lumpy. It should run at 2000 RPM after a cold start, reducing to about 1250 RPM once the throttle is used. That is how the factory spec carburettor works, the reduced fast idle is tripped when the throttle is blipped.
Nigel, I wonder if your fast idle speeds need adjusting?
Brucky
Post by Brucky » Fri Mar 01, 2019 7:40 am
Thanks for the suggestions as she’s going into the garage next week for alloy timing gear I will get this issue looked at. She always started perfectly on a fast idle no lumps from cold. This has crept in over the past few months regardless of the outside temp. I am hoping it’s something that needs adjusting or carb related
Brucky
Post by Brucky » Wed Apr 03, 2019 5:44 pm
Took took the Coupe to a carb specialist and ended up getting a new carb. Apparently it was completely worn out. It’s now set up properly. Starts from cold on the button no lumpiness. It drives a lot smoother and is more responsive and it idles significantly lower than before. It’s mad that one thing can make such a difference to the driving experience
