GTE Pedal Boxes
Has thanked: 316 times
Been thanked: 155 times
GTE Pedal Boxes
Post by MikeyBikey » Wed Feb 20, 2019 8:06 pm
I currently have the 5a pedal box with remote servo.
I want to upgrade to a servo attached to the bulkhead aka modern machinery.
However the accelerator cable on my pedal box will foul any bulkhead servo as the cable comes out of the bulkhead between accelerator andclutch master cylinders
so which GTE model solved this and how
Has thanked: 153 times
Been thanked: 1039 times
GTE Pedal Boxes
Post by scimjim » Wed Feb 20, 2019 8:22 pm
None off the shelf - however, an SS1 pedal box may work?
GTE Pedal Boxes
Post by MikeyBikey » Wed Feb 20, 2019 8:55 pm
ok, as ever thanks Jim :D
Has thanked: 73 times
Been thanked: 687 times
GTE Pedal Boxes
Post by philhoward » Wed Feb 20, 2019 9:01 pm
Chris (Dark Star) fitted an SS1 pedal box to his Coupe bit that was to get a cable clutch. You can fit a hydraulic master cylinder to that pedal box (albeit backwards) - Craig’s Sabre has it. I did a mock-up and it’s feasible if using one from a Transit Connect (cheapest I found as it was a mock-up)
SE6 (not 6a) pedal box was fitted to Andrew Collins’ Coupe but it was “a struggle” apparently.
AndyKing
GTE Pedal Boxes
Post by AndyKing » Wed Feb 20, 2019 9:24 pm
I've managed to fit a SE6a pedal box to my SE5, but it wasn't easy.
The pedal box needed a bit of modification and it's difficult getting enough clearance to the steering column. As you can see in the photos, the bulkhead needed major surgery. I can't say I'd recommend it unless you are feeling very determined.
roymck
Has thanked: 15 times
Been thanked: 24 times
GTE Pedal Boxes
Post by roymck » Wed Feb 20, 2019 10:23 pm
Nice bit of glass work there .
Has thanked: 166 times
Been thanked: 556 times
GTE Pedal Boxes
Post by Roger Pennington » Wed Feb 20, 2019 10:25 pm
Unless I'm missing something about Mike's requirement, I would have thought the 6-series pedal box was the obvious solution? (assuming that it's not too large to fit in the footwell?). Presumably Andy's bulkhead mods are as much a result of the size and new position of the servo, as the pedal box itself, and are always going to be a challenge if you go that way? But it will enable you to convert to dual-circuit brakes?
GTE Pedal Boxes
Post by scimjim » Wed Feb 20, 2019 10:35 pm
that’s the problem :D
GTE Pedal Boxes
Post by Roger Pennington » Thu Feb 21, 2019 1:09 am
Ah! I was assuming that as you'd suggested an SS1as a possible, then an Se6a ought to have a fighting chance, as my impression has always been that the SS1 pedals are more widely-spaced than the Se6a's (though the SS1 lacks space to rest your foot left of the clutch).
Any integral-servo option is presumably going to need changes on the engine side of the bulkhead, because of the way the servo is positioned (IIRC didn't Chris use a waste-paper bin to mould it on Dark Star?). I may be wrong, but I'm guessing Mike's objective is to get dual-circuit brakes? In that case, presumably this is pointing towards a dual circuit remote servo as a better option?
GTE Pedal Boxes
Post by philhoward » Thu Feb 21, 2019 5:56 am
This is Mikey logic - there may be a totally sensible reason why but then again this could be a sledgehammer and nut situation with a bit of bonkers thrown in for good measure. Remember this is the same guy who decides only a few days before Curborough to rip out his whole wiring loom and redesign it from scratch despite (by admission) being somewhat confused by electrics :mrgreen: :w 8)
GTE Pedal Boxes
Post by Roger Pennington » Thu Feb 21, 2019 11:39 am
Yes, that's true..... :P
GTE Pedal Boxes
Post by MikeyBikey » Thu Feb 21, 2019 7:47 pm
:lol: :lol:
And the night before curbs drop the box and change the clutch.....
although that was necessity
cheers all. the ask was brought about with the scimega conversion that as almost complete. I'm a tad aware with potentially 220 - 250 bhp I might need a servo , because at the moment i dont....
Has thanked: 24 times
Been thanked: 104 times
GTE Pedal Boxes
Post by Coupe Racing » Thu Feb 21, 2019 8:15 pm
I never used one with similar power
Better feel
GTE Pedal Boxes
Post by MikeyBikey » Thu Feb 21, 2019 8:33 pm
Agreed but this will be my regular daily and I'm just thinking I might actually need to start braking....
I'm running fords at the mo and I must admit their brakes are good. Very well balanced. My wife runs vauxhalls and their brakes are horrific. Far too strong.
GTE Pedal Boxes
Post by philhoward » Thu Feb 21, 2019 9:43 pm
So what’s wrong with the original type servo? Even if you go dual circuit, you can get remote dual circuit servos..
