Injection for an Essex
Ethanol
Post by Ethanol » Tue Feb 05, 2019 5:07 pm
I have a 1979 W reg Scimitar and I want to fit a multi-point injection system. Has anyone else done it?
When you increase the compression of any engine you make it more thermodynamically efficient, that makes it more powerful.
Been thanked: 562 times
Post by philhoward » Tue Feb 05, 2019 5:12 pm
Ethanol
Post by Ethanol » Sun Feb 24, 2019 5:05 am
That looks expensive my own engine is has a Weber DGAS, I'll fit a mega squirt ECU, convert the DGAS to a throttle body with a Volvo TPS fit the injectors and fuel rail from a 350Z. A Bosch inline pump. I need an injection system to convert my engine to ethanol.
Post by philhoward » Sun Feb 24, 2019 7:52 am
Are 350z injectors ethanol safe? I’ve seen mention of specific injectors for ethanol but usually referring to specific vehicles for the Brazilian market although Saab did an E85-compatible engine (and I’m sure others did too).
As a side note, that’s an odd choice for a Profile Signature:
Although ethanol has 3/4 the energy density of petrol it has really high octane I think if we convert to ethanol with high enough compression we can achieve more power. 275HP might be possible with an Essex engine, but you would need 16.5 to 1 compression.
Did you mean to reply to a post rather than add it as a signature?
Has thanked: 120 times
Been thanked: 891 times
Post by scimjim » Sun Feb 24, 2019 9:00 am
The Essex would be a good start for E100 as the additional loads at those kind of CR numbers would wreck most engines. The Essex is over-engineered thanks to it’s planned diesel application. It’s an interesting subject that hasn’t really taken off (despite being around for decades).
Has thanked: 212 times
Been thanked: 104 times
Post by MikeyBikey » Sun Feb 24, 2019 9:01 am
Still shorter then yours phil :lol: :lol:
Post by philhoward » Sun Feb 24, 2019 9:10 am
Which is shorter than Jim’s :mrgreen:
Been thanked: 90 times
Post by Coupe Racing » Sun Feb 24, 2019 11:49 am
The hardest part is modifying the inlet manifold to accept injectors esp the centre 2 as you won't get much of an angle
Ethanol
Post by Ethanol » Sun Feb 24, 2019 12:22 pm
The heavy build of the Essex engine is one reason why I use it. The heron head is the other, I was able to get cast pistons to fit easier I didn't need to go to the expense of forged domed pistons because of ethanol's low energy density. As the ethanol engine was an MoD radar station emergency generator I don't know what kind of cam it's got fitted. I do know if I re-built my Scimitar Essex to 16.5 to 1 it would do 275HP
Has thanked: 87 times
Been thanked: 59 times
Post by efi_sprintgte » Sun Feb 24, 2019 1:02 pm
We built a sprint car that ran a triple carb inlet manifold with 6 TBs. Proved to be far more tractable then triple carbs.
I don’t see how you can get that kind of CR from a Essex and still clear the valves? 11:1 is tight with 300/310 deg cam.
Ethanol
Post by Ethanol » Sun Feb 24, 2019 1:17 pm
As I said I don't know what cam it has, it might be the distance the piston is from the head at tdc
scimmy_man
Been thanked: 34 times
Post by scimmy_man » Sun Feb 24, 2019 2:29 pm
er???
Post by philhoward » Sun Feb 24, 2019 3:04 pm
er???
I was referring to the signature, Mike. 8)
scimmy_man
Post by scimmy_man » Sun Feb 24, 2019 4:16 pm
of course you were
Ethanol
Post by Ethanol » Mon Feb 25, 2019 12:15 pm
The injectors as is are might not be ethanol safe, but once I've remanufactured them they will be.
