engine number identification : advice
Mimic
Post by Mimic » Tue Nov 27, 2018 11:07 am
Hi,
I 've seen lack of compression on my engine so I need to pull out it the car. I've read the engine number ...and I was astonished by the result: XTEH16F572.
If I check the number on burton website , the short engine was built in 1999 (in South africa?) . I 've lot of bills from the previous owner but not before. My early se5 is 50 years old .
Does anyone could have an explanation or an idea?
Mimic
scimmy_man
Been thanked: 34 times
Post by scimmy_man » Tue Nov 27, 2018 12:50 pm
either Burtons are wrong
or someone swapped the engine
all scimitar v6 engines start SC.....
Has thanked: 137 times
Been thanked: 509 times
Post by Roger Pennington » Tue Nov 27, 2018 3:48 pm
That number doesn't look anything like the format of the Ford engine numbers according to Burton's site? If it was an August 1999 built Ford engine (fitted to a Ford car) then they suggest that the number would be XT12345 (where XT12345 is the same as the last part of the VIN). Your number seems to be a more random mix of numbers and letters. Where was it located. are you sure it is the engine number?
I'd agree with scimmy_man that original Scimitar engines were SCnnnnn
Has thanked: 130 times
Been thanked: 951 times
Post by scimjim » Tue Nov 27, 2018 4:11 pm
Samcor built Essex engines between 1982 and 2000 so it’s not much of a surprise to find a few in UK - normally the later 3.4 or the fuel injected 3.0.
Zimzum
Post by Zimzum » Tue Nov 27, 2018 4:19 pm
Hello,
Posting the photo for Mimic.
We will see if a plate was placed over the original number. It looks like a non original number.
Location : at the top edge of the bloc on the gearbox side, like our other Essex bloc
Post by Roger Pennington » Tue Nov 27, 2018 4:22 pm
Yes, I agree - could it be an engine reconditioner's number?
Post by scimjim » Tue Nov 27, 2018 4:26 pm
Pretty sure I’ve seen pictures of SA engines with that type of plate.
Pepe
Post by Pepe » Mon Dec 17, 2018 8:16 pm
My engine isn't original anymore.. The SC is not there. I got a Capri or Granada Engine beginning with Ford numbers. (unless very late 5a s had Ford numbers, but even 6 and 6as had SC Essex).
Mine is TR03519 HYB (Essex 3 Liter is HY engine type)
I guess an engine rebuilder would reuse the Engine number? So I'd double the SA thoughts...
1975 SE5a restoration link
Image Image
Has thanked: 50 times
Been thanked: 599 times
Post by philhoward » Tue Mar 12, 2019 2:45 pm
Here's one pic of one.
Mimic
Post by Mimic » Tue Mar 12, 2019 3:57 pm
Hard to find a "matching number " reliant scimitar :lol: (... that just a "porsche" owner preoccupation!).
After clean up my engine, the original number were deleted by a grinder machine.
The only information I've read : it were rebored + 0,30" (written near one of cylinder rank)
Post by scimjim » Tue Mar 12, 2019 4:02 pm
Really? I have two :D
TrevorG
Post by TrevorG » Tue Mar 12, 2019 4:31 pm
The reason that I am spending loads on rebuilding the engine in my repurchased 6a is that it is the original. Even though I purchased a working replacement, there is something satisfying that all bigger parts of the car are kept original. I'm sure there are still lots of other owners who have done the same.
