SS1 plus SS1 Turbo Parts for Sale
Locked
Littlescim
Post by Littlescim » Sat Oct 06, 2018 12:32 pm
HAVING A CLEAR OUT - ALL THESE ARE FOR SALE
1 pair of headlamp motors c/w linkage and lamp mounting screws - £50
1 LH & 1 RH electric window motors c/w regulators - £40
1 LH & 1RH rear brake back plates, drums & shoe fixing kits - £40
1 floor carpet, professionally cleaned and in VGC - £60
1 expansion tank - £10
1 good steering rack from 1600cc - £45
1 ignition lock/switch c/w 2 keys - £10
1 complete twin wiper mechanism (wheel boxes, tubes & motor) £25
1 LH & 1 RH headlamp unit shrouds (no cracks) - £20
1 column stalk assembly with terminal blocks from 1600cc - £20
1 heater fan motor - £15
1 battery tray - £10
1 new brake master cylinder for big brakes (Lockheed 13/16th bore) - £60
2 boot struts - £10
1 new speedo cable (1600cc) - £15
1 coil and transistor unit from 1800cc turbo (tested) - £30
1 coil and transistor unit (untried) - £20
2 distributors for 1800T C/W cap, rotor arm and leads - £50 each
1 1800 turbo exhaust manifold 10mm blank for making up a new manifold - £20
1 centre console C/W ashtray, heater controls, switches and Hitachi radio/cassette player from 1600cc - £40
1 type 9 gear box and bell housing from 39,000m SS1 1600cc - £220
1 1600 CVH c/w carb etc from 39000m car but suspect bent valve because previous owner tried to start without changing cam belt. I fitted new cam belt & engine runs on 3 cylinders - £100
All above parts available for collection or plus carriage at cost
Please PM for photos & additional info.
Dave
Has thanked: 354 times
Been thanked: 254 times
Post by Corky » Sat Oct 06, 2018 2:12 pm
I'd like the manifold blank please. I'll drop you a PM
old bean
Post by old bean » Sun Oct 14, 2018 10:53 pm
I'd like:
1 LH & 1 RH headlamp unit shrouds (no cracks) - £20 + postage price to UK mainland please
Taa
mikeh
Post by mikeh » Mon Oct 15, 2018 9:54 am
Hi,
If possible can I have the heater unit, the 2 boot struts and the tested coil and transistor for the 1800 ti.
How do you want paying ?
Mike
Elvis12
Post by Elvis12 » Mon Dec 17, 2018 5:37 pm
Hi I need two wing mirrors. Are yours the same as this? Thanks.
Post by Roger Pennington » Mon Dec 17, 2018 6:13 pm
That kind of mirror was never fitted to the Small Sports range - when they had electric mirrors, they used the "Ford" pattern, (similar to the left-hand one in your other diagram).
Locked
