Can I get a piston out with the engine in situ?
Jpwill7675
Post by Jpwill7675 » Tue Sep 18, 2018 7:38 pm
Hi - sorry if this is a daft question. My new acquisition has a noisy head. I checked the tappets which were ok. I did a compression check and one cylinder was very low. I took the heads off to reveal a loose valve seat. The head and the piston are coked up a bit but don't look damaged. However, there seems to be more play on the piston of the affected cylinder than the others. I guess it could be broken rings or at worst damage to the big end bearings?
Is it a big job to get the cylinder block off in situ or would i be better off taking the engine out of the chassis? The car is a rolling project so time is not an issue
Thanks for any advice.
Regards, Jim
PS . The engine was overhauled in 2001 with 20 thou rebore, mild road cam (might explain why the valve clearance seemed tight :oops: ) and unleaded valve seats. Its only done 13,000 miles since then
rebel alliance
Post by rebel alliance » Tue Sep 18, 2018 7:56 pm
If you remove the sump and undo the big end bearing cap , i don't see why you couldn't take the piston out the top..
Has thanked: 57 times
Been thanked: 87 times
Post by Oldconn » Tue Sep 18, 2018 8:09 pm
It should be possible. After all, one would normally replace the pistons from the top. My guess is you will find a sloppy little-end -been there ! :D
Has thanked: 85 times
Been thanked: 59 times
Post by efi_sprintgte » Tue Sep 18, 2018 8:13 pm
I’ve done it a few times, not normally through choice I might add
I tend to do that in situe at the “let’s asses what we’ve got here stage”
Been thanked: 876 times
Post by scimjim » Tue Sep 18, 2018 8:39 pm
I’d pull the block and do the core plugs if they’re 17 years old and been sat a while? You can do things in situ but unless you have a lift, you’re going to spend half the time on your back under the car - in the long run it’s always easier to do things on the bench.
Jpwill7675
Post by Jpwill7675 » Tue Sep 18, 2018 9:09 pm
Thanks Jim. I think I will take the whole engine out to get a good look at what I have. I can also check out the timing gear wheel. Are the core plugs an easy job ?
Jpwill7675
Thanks for all the suggestions
Post by scimjim » Tue Sep 18, 2018 9:10 pm
Core plugs are easy but the rear ones are inside the bellhousing and the front ones are behind the timing cover backplate.
