Electric fuel pump straight 6 engine
philynnbob
Has thanked: 64 times
Post by philynnbob » Tue Sep 18, 2018 12:45 pm
Instead of trying to reinvent the wheel :D
Not found in search.
Has anyone running a straight 6 engine with triple SU carbs,replaced mechanical fuel pump with an electric one?
Without the need of a separate pressure regulator.
If so any info would be gratefully received.
Thank you
Phil
Been thanked: 551 times
Post by philhoward » Tue Sep 18, 2018 12:49 pm
I think the only one that will be OK is - funnily - an electric SU pump.
philynnbob
Post by philynnbob » Tue Sep 18, 2018 12:56 pm
Yes :D
But which one will feed the triples throughout engine range maintaining 2.5 psi
Or am I having a senior moment again!
Post by Oaksey » Tue Sep 18, 2018 1:18 pm
Go on Burlens website and see what similar set ups use. I have a feeling a twin low pressure pump will be what you want
Post by philhoward » Tue Sep 18, 2018 1:19 pm
You might find an MGB one will suffice (assuming it’s the same one as used on an MGC)? An MGB one runs an Essex V6.
halfpenny
Post by halfpenny » Tue Sep 18, 2018 1:23 pm
Try a double SU pump as fitted to Astons; expensive, but does the job.
Joe.
Been thanked: 27 times
Post by Joe. » Tue Sep 18, 2018 1:54 pm
I'm using an MGA / MGB one on my straight 6. AZX1331
https://www.ebay.co.uk/itm/SU-FUEL-PUMP ... Sw43haKpwR
Post by Old and Slow » Tue Sep 18, 2018 5:26 pm
660XYB uses the standard SU pump for the three DCOE40 Webers at 2.5psi and is fine. the fuel pump switch is two-position, connects to one or two pumps, but the second pump is on the return feed back to the tank!!
I get around 15 mpg.
AllingtonGT
Has thanked: 28 times
Post by AllingtonGT » Wed Sep 19, 2018 3:25 am
I have triple Stromberg 97's on a flathead V8 that uses a progressive throttle linkage, so runs on the middle carb most of the time until you press the throttle which brings fore and aft carbs in to use. The differing cams means they are all fully open at full throttle. It's rare that I get the car fast enough to trouble the outer carbs. They were supplied by a front mounted SU pump through 3/16" copper.
The Strombergs are perhaps more sensitive than SUs to over-pressure and pressure fluctuations. Whilst the SU pump when checked provided the required 2.5psi, the constant pulsing seemed to upset the needle valves in the fuel inlet to the float bowl. The carbs leaked fuel from every joint and gasket and numerous rebuilds did not solve the problem. The heat generated by the flathead seemed to complicate things further causing vaporisation, but at least it meant neat fuel didn't run down the engine too far.....
Over the Summer I've changed the system. I tried fitting a new mechanical pump but that was a retro step in every department. It has to be left on the engine, but is now an ornament.
Taking advice I fitted a red top Facet pump at the rear, delivering at about 7psi and a regulator at the front set to 2.25psi. Fuel is delivered through new 8mm copper pipe front to back. I replaced the original brass and copper carb connections with banjo joints and 8mm rubber pipe to reduce vaporisation through heat sink.
What a transformation. The car starts more easily and is a complete delight to drive. The carbs (almost) aren't leaking at all, albeit I do have a few of the gaskets that suffered under the original system, so need changing again. The ability to adjust the regulator is very useful and I'm sure I will experiment with different settings. Knowing now that it delivers a constant 2.25psi is progress and it has made a huge difference to the way the car operates and runs.
I already have a similar set up on 359 JUA feeding the triple 40's, and that just works. I haven't checked the pressure it's set but feel sure it's about 2.5psi.
philynnbob
Post by philynnbob » Thu Sep 20, 2018 10:56 am
Emailed Burlen,reply here for future reference for others.
Now ordered :D
Post by Old and Slow » Sat Sep 22, 2018 9:40 pm
Hi Phil,
Your query got me thinking:
The Sabre Six has an LCS-type electric fuel pump; I've measured the pressure and it is 2.5 psi. The Burlen website tells us the pump can supply up to 12.5 gallons per hour.
I reckon I'm getting an average of 15 mpg at an average of 45 mph, which means a flow rate of 3 gallons per hour. At top speed this might be doubled, to say, 6 gallons per hour, well within the capability of the pump.
Note though, the fuel pipes are 3/8" or 10 mm, which shouldn't restrict fuel flow.
I hope this helps.
chrisgallacher
Been thanked: 34 times
Post by chrisgallacher » Sat Sep 22, 2018 9:47 pm
How do you measure the pressure out of interest Philip?
Chris Gallacher
RSSOC Rally Secretary
rally.secretary@rssoc.co.uk
Post by Old and Slow » Sat Sep 22, 2018 10:15 pm
I bought a fuel pressure gauge from Demon Tweeks:
https://www.demon-tweeks.com/uk/fse-in- ... ge-243255/
I also bought the adapter which fits in a length of hose.
Out of interest, the gauge isn't zero'd properly, it reads 1 psi, so is capable of measuring negative pressures!
I checked the calibration against another gauge I have, 0-60 psi (a bit insensitive for the lower range of the fuel pump) but it showed the gauge is accurate.
It isn't permanently installed, so let me know if you want to borrow it
