Wiring nightmare, help!
jlovie
Post by jlovie » Sun Sep 16, 2018 7:32 am
She was starting,fine but I've lost my before picture and now I'm completely lost. If anyone has a clear image of wires from coil and ballast resistor that'd be so appreciated. Getting an auto sparky out here in whops is goin to take for ever
jlovie
Post by jlovie » Sun Sep 16, 2018 7:37 am
See what I mean
Bloody shames
David Tew
Been thanked: 35 times
Post by David Tew » Sun Sep 16, 2018 8:09 am
This should clarify things:
PMA50_installation.pdf
(832.06 KiB) Downloaded 46 times
jlovie
Post by jlovie » Sun Sep 16, 2018 8:20 am
That looks like a great starting point thank you...
jlovie
Post by jlovie » Sun Sep 16, 2018 8:26 am
Voltage tachometer,
?, it has a piggyback on connector,standard?
Voltage tachometer,
David Tew
Post by David Tew » Sun Sep 16, 2018 8:53 am
Yes, on the -ve side of the coil if you have a voltage-sensing tacho. It will have the sensor feed to the tacho and the brown switch wire from the Lumenition module.
jlovie
Back to points, new dizzy, diagrams please?
Post by jlovie » Fri Oct 05, 2018 4:53 pm
So fried lumenition module, new dizzy in place, back to points for now, any original wiring diagrams would be appreciated, just to be sure
Been thanked: 90 times
Post by Coupe Racing » Fri Oct 05, 2018 5:41 pm
Wiring for the standard set up or the luminition
jlovie
Post by jlovie » Fri Oct 05, 2018 6:11 pm
Standard set up, goon back to basics until I decide on new unit,
Has thanked: 128 times
Been thanked: 937 times
Post by scimjim » Fri Oct 05, 2018 6:27 pm
Wiring diagrams here
jlovie
Post by jlovie » Sat Oct 06, 2018 4:17 pm
Dizzy in place and assume earthed through fixing so lead from dizzy to replace brown lumenition lead as shown, correct?. Only connection lead can reach so assume I'm right, but assumptions got me in this pickle to start with
Post by scimjim » Sat Oct 06, 2018 5:04 pm
Black and green from the coil minus (-) side to dizzy.
jlovie
Post by jlovie » Sat Oct 06, 2018 5:24 pm
So replacing brown shown is?
jlovie
Post by jlovie » Sat Oct 06, 2018 5:25 pm
Bearing in mind lumenition is gone now so back to standard
Post by scimjim » Sat Oct 06, 2018 5:27 pm
The brown isn’t original, so I have no idea I’m afraid - is it coming from the coil or is it a positive feed?
