SE5 Electronic Ignition Options?
jibowski
Post by jibowski » Wed Jul 18, 2018 6:52 pm
I'm wanting to convert my SE5 from contacts to electronic ignnition and I was wondering what the membership thinks is the best option for an upgrade based on their cars, there's various cheap crap kits on ebay but also seen these available
Lumition kit
http://www.burtonpower.com/lumenition-p ... pma50.html
Full electronic distributor conversion
http://www.burtonpower.com/electronic-d ... 445ak.html
Aldon Ignitor
http://www.burtonpower.com/aldon-ignito ... n1869.html
Thanks in advance for your seasoned opinions!
Been thanked: 877 times
Post by scimjim » Wed Jul 18, 2018 8:55 pm
I have an accuspark (for a fraction of the cost of those).
Rev Light
Been thanked: 24 times
Post by Rev Light » Wed Jul 18, 2018 9:48 pm
another vote for accuspark.
SE5a 'Fancier'
Has thanked: 85 times
Been thanked: 59 times
Post by efi_sprintgte » Wed Jul 18, 2018 9:48 pm
Yeah, I’ve used that on standard road cars 4 times now. All good :)
I have to say... I don’t like lumination, they can be annoyingly unreliable.
I did 50,000 miles on a Aldon Igniter and that was fine too.
jibowski
Post by jibowski » Wed Jul 18, 2018 11:24 pm
My coil is ancient so I'll go for a new coil as part of the kit, Does anyone know whever the blue Lucas DLB110 Specification, or the Red Lucas DLB105 Specification is the right one for an SE5, they're both for the motorcraft/fomoco dizzy.
Blue
Red
thanks for your help so far :D
Post by scimjim » Thu Jul 19, 2018 12:00 am
Lucas DLB110 if you have a ballast resistor or eureka wire, DLB105 without.
Has thanked: 123 times
Been thanked: 23 times
Post by willholderogri » Thu Jul 19, 2018 6:57 am
I have been using accuspark (but I would avoid the stealth version ) I may have had a Friday and Monday one but it never worked properly from the word go. ok in the heat but useless when it was cold and I was driving all last winter so it gave me lots of grief.
I am temporarily on points again. but intend to go to a six pack coil and trigger.
Has thanked: 63 times
Been thanked: 90 times
Post by b.c.flat hat » Thu Jul 19, 2018 8:28 am
Hi Jib, just my two pennies worth. I've got Lumenition on my 5a, but only had it for 27 years with no problems so it may be crap😉
Been thanked: 330 times
Post by peter freeman » Thu Jul 19, 2018 8:40 am
I run lumenition on our Coupe and previously had it on a 5A and 6A - never had any problems.
Jimscim
Post by Jimscim » Thu Jul 19, 2018 8:47 am
Pertronic Ignitor , third v6 I have had it on , easy to fit works well , Happy days .
RSSOC 3408 1979/80 Scimitar 6a . Mulberry / white .
MarkHawkins
Post by MarkHawkins » Thu Jul 19, 2018 11:45 am
My 6a came with Lumenition which combined with electric fuel pump and a modern starter eases starting after a week or two of rest. That said, I've found points ignition on all the other Essex V6 cars I've had quite adequate (occasional use) and very easy to maintain / fix.
Custodian of :
1968 '4b Coupe HBL 725G
ex 1974 '5a auto - VLN 826M
Jimscim
Post by Jimscim » Thu Jul 19, 2018 12:49 pm
I agree , points ignition does do the job but over time points do deteriorate. Modern points IMHO are not as good as the original Lucas . Once the Electronic ignition is set up it is fit and forget .
