Fuel pump relay.
Wasman
Fuel pump relay.
Post by Wasman » Mon May 21, 2018 11:56 am
Hi Guys,
I'm chasing an annoying misfire and I'm wondering if a relay that pulls in the fuel pump and ignition might be breaking contact momentarily. I have a Durite 180 amp relay and that's probably overkill for a furl pump and ignition. It's been there since I've had the car.
Any sugestions what current rating I should go for with a replacement? 30A?
I can't see the pump but I wouldn't have thought it draws more than a few amps? And the ignition can't be more than 5 surely?
Any sparkys want to chip in?
Monster relay currently fitted.
Been thanked: 534 times
Fuel pump relay.
Post by philhoward » Mon May 21, 2018 11:57 am
A 30A relay would normally do the job and is the "standard" relay rating for automotive use.
Wasman
Fuel pump relay.
Post by Wasman » Mon May 21, 2018 8:22 pm
Thanks Phil,
Have one on order, I'll keep you posted. (I probably have several in a box *somewhere*, but at £2.99 delivered on fleabay who could argue?).
Mark.
