Scimitarweb Problem Today
Can't register?
Has thanked: 166 times
Been thanked: 556 times
Post by Roger Pennington » Tue Sep 15, 2009 12:57 pm
All morning I have been unable to log-in and post messages. I have been getting a message along the lines of "unable to find the server shworth.com...." At the same time RSS, which I normally find totally reliable, is not working and is giving me a message "Internet explorer is unable to update password-protected feeds" which again presumably relates to a failure to logon. As you can see the first problem now seems to have gone away, however the problem with RSS still remains. Is anyone aware of the existence of a particular problem, or of any work-in-progress which could cause this?
thanks fo your help,
Has thanked: 153 times
Been thanked: 1039 times
Post by scimjim » Tue Sep 15, 2009 1:09 pm
Roger, no problems my end - I've been online continually since about 0700 at home (left logged in and just used it at lunchtime) and work. Steve in SA, CNH & mikerf have all been online too and no mention of problems.
erikscimitardemon
Been thanked: 21 times
Post by erikscimitardemon » Tue Sep 15, 2009 1:15 pm
Roger,
Try again with www.scimitarweb.com/sgwrs
It seems www.shworth.com is not reachable, so www.shworth.com/scimitarweb/sqwrs does not work either.
Erik Hofman
http://www.scimitar.demon.nl
Post by Roger Pennington » Tue Sep 15, 2009 1:58 pm
Thanks Erik, that does appear to work. However a couple of points:
The failure on attempting to reply was happening immediately on pressing the "reply" button at the bottom of the thread - instead of showing me the login screen as usual, it was giving the error. I don't understand why that failed for me, but appears to work ok for others? Surely what happens when you press a button (when already on the site) is always the same?
Second, In order to make the change you suggested, I had to resubscribe to the RSS feed and effectively set it up again. Hopefully this will be a permanent change? I get the impression that if we make frequent changes to RSS then (as well as being a nuisance) we may cut-off people who find it a usefull way to keep up-to-date with the forum, as I get the impression that general knowledge of RSS is limited.
cheers,
erikscimitardemon
Post by erikscimitardemon » Tue Sep 15, 2009 2:11 pm
All URLs to shworth. etc were a temporaly solution to hosting problems.
When the problems were solved, by hosting the site at Alyns own provider, no one ever thought of renaming a small setting back to scimitarweb.
I just renamed it. Now it has the name again it should have had for a long time.
Erik Hofman
Post by scimjim » Tue Sep 15, 2009 5:00 pm
as soon as I pressed send (above) on my computer at work - it crashed! perhaps that was Erik renaming the url because all of my links pointed to www.scimitarweb.com
penfold
Post by penfold » Wed Sep 16, 2009 7:17 pm
Don't know if it's related, but the online club shop is similarly non-functional?
1986 1300 SS1
Offers: nowt at the moment
Wants: rollover bar, hardtop, interior mirror, manual driver's door mirror, type 9 gearbox, world peace...
erikscimitardemon
Post by erikscimitardemon » Wed Sep 16, 2009 7:27 pm
It probably is. At least it is hosted at shworth.com.
As I am only a forum admin, I do not have access to the shops internals.
Erik Hofman
Post by scimjim » Wed Sep 16, 2009 7:27 pm
certainly is - and I can't log into the admin side of the shop either - even going through scimitarweb instead of shworth
Has thanked: 285 times
Been thanked: 225 times
Post by Corky » Fri Sep 18, 2009 3:45 pm
I'm having a problem with it today. Is the online shop down ? I'm trying to pay my subs, but can't access the shop for some reason. I'll have to do it the old fashioned way. Now where did I put my chequebook..........?
Post by scimjim » Fri Sep 18, 2009 4:01 pm
Steve, if the shop is down at any time you can email an order direct and pay directly with PayPal to merchandise@rssoc.co.uk
Post by Corky » Fri Sep 18, 2009 4:16 pm
Thanks Jim, that sounds like an easy solution. I'll get onto it.
Post by Roger Pennington » Tue Sep 22, 2009 10:06 pm
Is anyone making changes to the website? following the problem that I reported above, I made the changes suggested, and everything was working perfectly, with the website and RSS back to their usual reliable selves. However this evening RSS suddenly seems to be falling apart, missing whole batches of messages, which is a real pain.
Thanks for your help,
Tony Dickinson
Post by Tony Dickinson » Wed Sep 23, 2009 12:11 am
Roger Pennington wrote:Is anyone making changes to the website? following the problem that I reported above, I made the changes suggested, and everything was working perfectly, with the website and RSS back to their usual reliable selves. However this evening RSS suddenly seems to be falling apart, missing whole batches of messages, which is a real pain.
I have lost RSS feed 'cos it was via shworth.com but cannot restart it via scimitarweb.com 'cos there is no RSS feed URL. Also most of the links inRSS messages refer to shworth.com which is unreachable...
Tony - from sunny Somerset
1972 SE5a - MOT fail in 1989!
Target rebuild date?????
Tony Dickinson
Post by Tony Dickinson » Wed Sep 23, 2009 12:23 am
Tony Dickinson wrote: I have lost RSS feed 'cos it was via shworth.com but cannot restart it via scimitarweb.com 'cos there is no RSS feed URL. Also most of the links inRSS messages refer to shworth.com which is unreachable...
Thanks Roger I think I have it sorted now...
