SE6 suspension query
stevey
Post by stevey » Wed Dec 06, 2017 3:57 pm
[attachment=0]5BE2875F-A7A9-4611-B426-ACDAF02DF44D.jpeg[/attachment
Your help would be appreciated I am trying to rebuild a 1979 SE6 and I was offered a far better condition front suspension than mine. It went together well until I attempted to fit the shock absorber. I am converting from a power steering to manual set up but as you can see the shock absorber has a lean rear wards and the coil spring fouls the upper wishbone mount. I am a bit lost, any experts got any ideas?
Has thanked: 106 times
Been thanked: 806 times
Post by philhoward » Wed Dec 06, 2017 4:02 pm
Touching, or can't fit it because of the collision?
You might find that when the suspension is loaded, that will swing the coil/damper unit away from it.
Also - are the shims fitted because that's what was there before, or have you measured the camber angle based on the normal ride height?
Post by philhoward » Wed Dec 06, 2017 4:03 pm
"Standard" ride height bar dimensions here: http://www.scimitarweb.co.uk/sgwrs/view ... ar#p415641
rebel alliance
Been thanked: 89 times
Post by rebel alliance » Wed Dec 06, 2017 4:03 pm
Correct trunnion ?
Post by Roger Pennington » Wed Dec 06, 2017 4:05 pm
Have you altered the lower wishbone mounting brackets?
I'm assuming it must be the correct trunnion, as I think it's unlikely you could get a PAS one in without extreme force?
stevey
Post by stevey » Wed Dec 06, 2017 4:34 pm
The trunnions are in good order but came from a PAS set up, what is the difference between Pas and manual steering trunnions?
Post by philhoward » Wed Dec 06, 2017 4:35 pm
About 8 degrees of angle...
stevey
Post by stevey » Wed Dec 06, 2017 4:36 pm
Feck! I think I have my answer! Are those shims in the correct place in relation to the mount an plate?
Been thanked: 417 times
Post by peter freeman » Wed Dec 06, 2017 4:47 pm
From the photo it does not look like the right brackets Roger. Stevey they are also sided so make sure you get the right ones on the right side - all four need to be replaced.
Post by Roger Pennington » Wed Dec 06, 2017 4:47 pm
I'm amazed that you managed to assemble it with a PAS trunnion! :shock: You must have had to really heave on the upright to make up the 8 deg missalignment at the top?
That still doesn't answer the point about the lower wishbone brackets - if you haven't changed them from the PAS setup, then the lower wishbones will be wrong.
Post by Roger Pennington » Wed Dec 06, 2017 4:50 pm
Yes, I didn't think they looked right either, though it's difficult to be absolutely sure from a photo - I asked the question to confirm my suspicions.... :wink:
Post by peter freeman » Wed Dec 06, 2017 4:57 pm
From this picture you can see that the bracket bolts are off centre - the manual steering has them at centre. You can also just see the angle of the trunnions -
with the manual they are not angled.
Post by Roger Pennington » Wed Dec 06, 2017 5:06 pm
Not correct, Peter, - the Manual and PAS systems use the same brackets, but they need to be assembled on opposite sides of the car, so that the offset is towards the front on a manual car, and towards the rear on a PAS car
(brackets with the bolts centred are a 5/5a thing)
Post by peter freeman » Wed Dec 06, 2017 5:08 pm
Yes you are right - it looks like a 5 bracket fitted hence my error without thinking properly.
Has thanked: 167 times
Been thanked: 1172 times
Post by scimjim » Wed Dec 06, 2017 5:11 pm
They do look a bit like 5/5a brackets fitted?
