Been thanked: 65 times
Post by BigBobPilot » Fri Jan 12, 2018 9:37 pm
I didn't reply about the shoulder straps, as I've used the cage harness bar. I did look at bolting back to the chassis, but as it drops away I was looking at making a small tower bracket to bring the mounts level. I think other people have bolted a bar across the chassis to get a level mounting, but that's usually when they haven't got a full cage.
The seat mount looks good. What's the crotch strap plate extending forward for?
SS1 CA18DET race car in build
Benc
Been thanked: 23 times
Post by Benc » Fri Jan 12, 2018 10:00 pm
Cheers Ben I m pretty sure the harness will be in the acceptable region around the harness bar so I'll go with that.
Plate extending forward...... indecisiveness.... when I put the seat in with the existing rails fitted I thought that to get the hole in the correct position i.e. Within 20 deg to the vertical the mounts would be slightly in front of the seat rail, after re checking they are slightly behind, I'll probably cut the front part off with grinder :? :shock: :(
Post by BigBobPilot » Fri Jan 12, 2018 10:16 pm
Ah, ok. I was expecting a cunning plan!
Benc
Post by Benc » Fri Jan 12, 2018 10:36 pm
I should of said it was an under car down force device!
Or a floor support :D
Benc
Post by Benc » Sun Jan 21, 2018 4:55 pm
Few more jobs done
Floor eyes fitted for 6 point harness and floor glassed back in
New 4 point cage means narrow tank
Just got to make an adapter for fuel filler hose and fit seat then should be running again😀
Has thanked: 154 times
Been thanked: 158 times
Post by Corky » Sun Jan 21, 2018 5:22 pm
Nice work!
Benc
Post by Benc » Sun Jan 21, 2018 5:29 pm
Cheers Steve the tank was a snug fit but really happy with it and progress. Your sketch dimensions were very helpful. Ta
Benc
Post by Benc » Sun Jan 28, 2018 6:44 pm
This weekend bit more progress, seat back in, fire extinguisher mounted on floor, hardtop mounted....
Ive made the brackets to hold the hardtop in place however the drivers side window is hard against the hardtop grp and the passengers side has a 30mm gap :shock:
Also you might see in the pictures the gap between the deck and the top is different larger passenger side
It as if it is slightly to narrow behind the b post...
Are they all like this??
Any advice?
Been thanked: 876 times
Post by scimjim » Sun Jan 28, 2018 7:37 pm
the brackets that hold the standard seat belt top mount (and the soft top frame or HT brackets) have slotted holes to allow you to tension the soft-top or position the hardtop. Slacken the 3 bolts off and push down on the HT.
Post by Corky » Sun Jan 28, 2018 7:40 pm
I can’t remember if I chopped the excess moulding of the area of the HT that meets the deck. Just have a check as there’s a score mark on all of the areas that need trimming.
Post by scimjim » Sun Jan 28, 2018 8:00 pm
ah - I forgot it was that HT :D
Benc
Post by Benc » Sun Jan 28, 2018 8:04 pm
I'll have a further look, it is touching drivers side and across the rear deck. Although at the b pillars there is a gap between hardtop and body.
However it doesn't really want to push down further, perhaps a few more mm removed across the rear deck might help. Although it is close to the rollbar and I had to remove the top rollbar padding
More sure how to sort the different gaps at the door windows is drivers no gap and passenger 30mm!
Yes this hardtop hasn't ever been fitted to a car so could be it's not perfect fitting :w :w :w
Post by Corky » Sun Jan 28, 2018 8:32 pm
Maybe if you get the glass in it’ll align the rest of it.
Benc
Post by Benc » Sun Jan 28, 2018 8:35 pm
I'll give the glass idea a try, it will at least suggest if the rear shape is ok.
Dave 6726
Has thanked: 53 times
Post by Dave 6726 » Sun Jan 28, 2018 9:41 pm
I fitted a HT to my SS1 just before Christmas and had exactly the problem you have. It's very slightly irritating, but no more.
My own thought on this (which may be totally wrong - I'm no expert) is that if any body panels on this model are ever removed/replaced, unless scrupulous care is taken, there is a good chance of misalignment. My own car is a total rebuild by a PO. I suspect that if re-assembly is/was not carried out with a HT in place, minor misalignment can occur. In my case the HT is neat on the O/S, but is about 10mm high in the way of the N/S B-post.(And, BTW, the shut lines all over are not as good as some others I've seen - perhaps slippage with flexing.)
