Bogging at 4000 rpm
Been thanked: 118 times
Bogging at 4000 rpm
Post by DARK STAR » Thu Jun 08, 2017 8:57 pm
Unfortunately I rarely extend the car nowadays but I couldn't resist putting a modern GTI boy racer in his place the other day.
Luckily it was in town so when the engine bogged at 4000 rpm I was far enough ahead and he was't going to go any faster ;-)
I think (hope) this problem is due to the appalling state of the air filter, which is after all 25 years old :oops:
So, after extensive research on K&N's site I thought I'd fit one of these (56-1360).
It is for twin Weber 45/48 DCOE's so should flow enough air ???
Difficult to calculate the volume because the inlets on the injection are square, as is Ford's wont and everybody else's are round :roll:
I need to get it right first time because the thing costs a fortune ...
Has thanked: 287 times
Been thanked: 155 times
Re: Bogging at 4000 rpm
Post by efi_sprintgte » Thu Jun 08, 2017 9:23 pm
Is it for your 2.9?
Post by DARK STAR » Thu Jun 08, 2017 10:06 pm
Yes, sorry, should have said ...
Post by DARK STAR » Fri Jun 09, 2017 7:17 pm
Nobody in a position to comment?
Please!
Has thanked: 178 times
Been thanked: 1231 times
Post by scimjim » Fri Jun 09, 2017 7:21 pm
Not without a pic of your AFMs and spec of filter. Are the AFMs mounted at the wing, which way round and how far apart? If the filter will physically fit I reckon it should flow enough (guess from pic only).
Post by DARK STAR » Fri Jun 09, 2017 7:29 pm
Meters are mounted on their sides, not sure how far apart but I can modify the filter housing.
It WILL fit 8)
Thanks Jim
Post by efi_sprintgte » Fri Jun 09, 2017 9:32 pm
My 2.9 had pipercross air filters with the square flange and bolted straight on.
Post by DARK STAR » Fri Jun 09, 2017 10:08 pm
Filters plural?
My airflow meters are mounted too close together ...
The present foam filter is Pipercross but all hacked about for the square inlets, I want something more elegant 8)
Post by scimjim » Fri Jun 09, 2017 10:23 pm
Mine was appalling and I cleaned it but never got round to replacing it :oops:
Post by efi_sprintgte » Fri Jun 09, 2017 11:02 pm
DARK STAR wrote:Filters plural?
Yes, it was a kit for a XR4x4i. One nice neat filter per AFM.
Ran 200bhp with that set up fine (the restriction was the AFM themselves)
Post by DARK STAR » Sat Jun 10, 2017 7:05 am
Yours is neat Jim, is it an Edelbrock?
Do you remember the model?
Post by scimjim » Sat Jun 10, 2017 8:30 am
I don't Chris - but it wasn't Edelbrock, perhaps an old pipercross?
Post by DARK STAR » Sat Jul 01, 2017 3:14 pm
A partial result, now it is just a bit hesitant at 4 000 rpm.
It is much prettier though 8)
Next up, I think the spark plugs, which are not as old as the filter but may be a bit tired.
I have a set in stock for some reason (perhaps I was already going to change them years ago ...)
Here's one I prepared earlier -
forum filter 1.jpg (468.81 KiB) Viewed 4644 times
forum filter 2.jpg (398.39 KiB) Viewed 4644 times
forum filter 3.jpg (411.95 KiB) Viewed 4644 times
Post by DARK STAR » Sat Jul 01, 2017 3:15 pm
part 2
Note the genuine Daimler SP250 bonnet stay
forum filter 4.jpg (485.19 KiB) Viewed 4642 times
forum filter 5.jpg (394.77 KiB) Viewed 4642 times
forum filter 6.jpg (477.9 KiB) Viewed 4642 times
Bogging at 4000 rpm
Post by DARK STAR » Tue Aug 29, 2017 6:40 pm
New Bosch plugs fitted.
The engine is now more supple at low revs - and doesn't want to go over 3500 rpm :roll:
Before it accelerated ok up to 4000 then it was as if there was a rev limiter cutting it.
Now it is reluctant to accelerate hard and won't go over 3500 unless I go gently.
Effectively it is the opposite to Vert Soleil which runs ok at high revs but won't idle :|
I am getting tired ...
Return to “Middlebridge”
