reversing light switch
Been thanked: 438 times
Post by peter freeman » Tue Jan 10, 2017 1:11 pm
Before I start to find out why my reversing lights have failed can anyone tell me where the switch is on the gearbox. Should it come to that I would like to know which side of the car I have to jack up to get at it.
1969SE5
Re: reversing light switch
Post by 1969SE5 » Tue Jan 10, 2017 1:15 pm
Mines a switch on the dash
Has thanked: 52 times
Been thanked: 322 times
Post by AJL Electronics » Tue Jan 10, 2017 1:16 pm
Is this on the auto Peter? If so it is the combined inhibit and reverse switch same side as the shift linkage and slightly above. Fragile to remove apparently, you need a box spanner I'm told.
If it is the manual, then I have no idea.
Has thanked: 133 times
Been thanked: 877 times
Post by philhoward » Tue Jan 10, 2017 1:20 pm
If manual, I would guess its right under the gearlever, driver's side.
Post by peter freeman » Tue Jan 10, 2017 1:22 pm
Yes its a auto - just been out for a look and find that its intermittent so it can wait until the summer. Knowing where it is helps though - thanks Andy.
Post by AJL Electronics » Tue Jan 10, 2017 1:23 pm
If it is the auto, the plug may have worked loose. However I would expect that to cause starting issues too, as the inhibit relay will lose its ground.
Post by peter freeman » Tue Jan 10, 2017 1:27 pm
Never had trouble starting but it could just be a bad connection on the lights side of the switch/plug.
Post by AJL Electronics » Tue Jan 10, 2017 1:38 pm
Post by peter freeman » Tue Jan 10, 2017 1:42 pm
A picture is better than thousands of years - thanks yet again Andy
midscotscim
Post by midscotscim » Thu Jan 12, 2017 9:03 pm
I had this problem a while back, 12V for this comes via a connector mounted just forward of the wiper motor. It also feeds the kick down switch mounted on the throttle body. This connector seems to be prone to water ingress, despite the crimp terminals visually appearing to be in good condition, one of them had corroded badly at the thinnest part of the crimp and fell apart while checking for continuity. Might be worth checking before getting under the car.
Regards, Mark.
Black Middlebridge
Post by peter freeman » Thu Jan 12, 2017 10:15 pm
Thanks Mark - will look when it gets warmer.
Return to “Middlebridge”
