Manny's SS1 1600
Been thanked: 164 times
Manny's SS1 1600
Post by reliant-reviver » Mon Jul 08, 2019 12:27 pm
Have you compared the shock absorbers to determine they are identical? Unlikely but someone could have substituted something odd into one side.
Tyre profiles same both sides?
manny
Been thanked: 26 times
Manny's SS1 1600
Post by manny » Mon Jul 08, 2019 12:49 pm
was thinking that (shocks)..profiles are the same... :(
having said that the 'new' shock units were the exact the same length and construction, and i did install in the same orientation...
manny
Manny's SS1 1600
Post by manny » Mon Jul 08, 2019 6:00 pm
Well I dropped off the car for its MOT and spoke of the issue - they will take a thorough look for me
manny
Manny's SS1 1600
Post by manny » Tue Jul 09, 2019 5:23 pm
Good day all
Front springs arrived :) (Ta RR)..and the car passed its MOT, so I guess the rear end is in order, I pick it up tomorrow so will have a chat :?
Ta
Manny
manny
Manny's SS1 1600
Post by manny » Wed Jul 10, 2019 2:06 pm
Good day folks,
picked up the car with new MOT .. :D , spoke with the chaps about the rear - they said nothing obvious was visible with the suspension setup etc, and they measured the difference at 3/4 inch .. :? :?
I will replace the fronts over the weekend and report back...
Ta
Manny
Has thanked: 33 times
Been thanked: 51 times
Manny's SS1 1600
Post by Alan SS1 » Wed Jul 10, 2019 9:20 pm
manny wrote:
Fri Jun 21, 2019 1:14 pm
Good day folks
right....measurements are as follows:
ground to jacking, gap between arch and wheel top
NSF: 6", 2"
NSR 6",0.5
OSF:5.5", 1.5
OSR 5", -1.x "
so will be swapping units between sides today and remeasure on Sunday ....but seems conclusive ..?
Ta
Manny
step back a moment,
it would appear from above that there is only a small difference at the front? ie half inch at front
yet at the rear there is nearly one inch (now reduced to 3/4" after all the changes.
so if there was a problem caused by the front then surely the differnce would be as big or bigger there.
I'd ignore arch to wheel heights as the framing could be skewed , NB 'panel fit' only means that the panels were fitted, not always aligned , well possibly to the stars?
manny
Manny's SS1 1600
Post by manny » Wed Jul 10, 2019 9:48 pm
step back a moment,
so if there was a problem caused by the front then surely the difference would be as big or bigger there.
yes sir- that makes sense..my main concern is the rubbing of tyre on the arch...before the new springs and with a passenger we could hear and smell the tyre rubbing!..i have to say it's only occurred in the last six months and never noted the issue before.
Looking back at the images when i first bought the car, there is a slight difference , we will see what unravels over the weekend, i will remove the boot and take some measurements..
Ta
Manny
Manny's SS1 1600
Post by Roger Pennington » Wed Jul 10, 2019 10:06 pm
What age is the car? or to be more specific, does it have the early or late rear inner wheel arches? The later ones were wider and give slightly more clearance, especially if you've got wider wheels/tyres.
manny
Manny's SS1 1600
Post by manny » Thu Jul 11, 2019 6:23 am
Morning sir, well it's an 85 model with standard 185/6o R14 tyres...what are the width differences?
Ta
Manny
Manny's SS1 1600
Post by Alan SS1 » Thu Jul 11, 2019 12:51 pm
Ta
Manny
dunno but I'm running 'bottle tops' with original arches on an 'early' 1985 version without issues, except if fully loaded then buffs top of arch on bigger bumps . . .
Manny's SS1 1600
Post by Roger Pennington » Thu Jul 11, 2019 12:53 pm
Unfortunately I can't remember when the changeover was. :oops: There are a number of references to it on the forum, eg here, but no changeover date. Now with standard tyres & wheels, it shouldn't matter (though it's worth noting that some tyres of the same spec can be different widths to others). However it might mean that you've got less margin for error, if something else is a bit out?
manny
Manny's SS1 1600
Post by manny » Sat Jul 13, 2019 2:48 pm
Good day,
i did not change the front springs as i had a trip up to Nottingham, however when i arrived i parked with the nearside on the kerb, and by chance noted that the offside arch gap was now the same as the nearside, i could get my hand between the tyre and arch....that makes no sense or logic to me... :? :? :?
confused
Manny
manny
Manny's SS1 1600
Post by manny » Mon Nov 25, 2019 1:35 pm
Good day all
the cars been running fine.. :D only slight issue today was that the temperature gauge swung all the way to the HOT sector when the ignition was on but car not started , as the fuel gauge was reading okay, i have to assume the instrument voltage regulator is okay....
In terms of testing ...is the correct sensor the one on the thermostat housing with a single wire, if i remove that wire and the gauge reads zero ..that will root the sender as the issue and i guess an OHM reading on the spade and body of the sensor will show a short ?
Ta
Manny
Has thanked: 131 times
Been thanked: 871 times
Manny's SS1 1600
Post by philhoward » Mon Nov 25, 2019 1:37 pm
First guess would be the wire has fallen off and is shorting out on something as that will send it to max.
Has thanked: 189 times
Been thanked: 1274 times
Manny's SS1 1600
Post by scimjim » Mon Nov 25, 2019 1:37 pm
It’s not on the stat housing (that’s the awkward 2 wire plug for the cooling fan), it’s by the no4 exhaust port (single wire sensor). It might have just fallen off and/or shorted to earth giving you max reading.
