Good or Appropriate Number Plates
Been thanked: 614 times
Post by philhoward » Thu Apr 11, 2019 8:59 pm
Roger Pennington wrote:
Thu Apr 11, 2019 6:11 pm
And also you can't just walk in off the street and order a vehicle plate, you have to produce proof of ID and Vehicle ownership (normally the V5)
Supposedly.... :W
Amazing how many eBay sellers seem to “forget” to ask for the required documentation. Halfords, on the other hand, seem to need the deeds to your house and a letter signed by two barristers in comparison. Unless the car is outside the shop, of course - which nullifies the requirement.
Has thanked: 59 times
Been thanked: 35 times
Post by Will Anderson » Thu Apr 11, 2019 9:17 pm
Thu Apr 11, 2019 1:59 pm
And it doesn't have to be obvious -
Oh how I wish more suppliers would take that stance. I dislike having to have the supplier name on the plate and even more when they use a large font size or a panel below advertising the garage.
I specifically got MB14's plates produced in the size and font used in 1989 - without any supplier identification - and they have passed all the MOT's since I fitted them. The SE5a's are black and white with no identifier either. I have resisted the temptation to replace the plates on the moderns. :roll:
Has thanked: 144 times
Been thanked: 521 times
Post by Roger Pennington » Thu Apr 11, 2019 11:55 pm
I'm sure they'd be fine, because they're not date-stanped, and there's no requirement to retrofit new style ones, so the MOT would just consider them as though they were fitted when new.
Post by Will Anderson » Fri Apr 12, 2019 7:15 am
Yes, that was my reasoning but it depends on the officiousness of the MOT tester. Thankfully the ones round here seem to be reasonable in that respect.
Been thanked: 80 times
Post by DARK STAR » Fri Apr 12, 2019 7:19 am
Isn't the MoT supposed to be a test of safety and roadworthiness ? 8)
Post by Will Anderson » Fri Apr 12, 2019 7:25 am
Ah, but to be safe they have to be able to read your number plate to fine you for being unsafe! :lol:
Has thanked: 135 times
Been thanked: 964 times
Post by scimjim » Fri Apr 12, 2019 8:28 am
Postcode, BS marking and any logos aren’t checked on the MOT.
Been thanked: 113 times
Post by gtcse8 » Fri Apr 12, 2019 8:40 am
And judging by a lot of the "Non Regulatory" plates that are pictured on here there are a lot of blind testers. :w
Post by scimjim » Fri Apr 12, 2019 8:43 am
I suspect a lot of people fit “MOT standard plates” for one day of the year, the same as others refit their catalytic converters etc,
Post by Roger Pennington » Fri Apr 12, 2019 11:54 am
The MOT test, is a test of compliance with the MOT rules, which is a subtly different thing.....
Post by scimjim » Fri Apr 12, 2019 12:06 pm
I’d say they’re both the same?
Post by Roger Pennington » Fri Apr 12, 2019 12:14 pm
I don't believe so - The MOT requirements are obviously the same as the legal requirements that they reference and are based on, but there are a good many things on which the MOT requirements are silent, but which are in the overall C&U or related regulations. A couple which spring to mind are over-dark tints on front windows and high wattage headlamp bulbs. So just because your car passes an MOT, doesn't necessarily mean it's completely safe and legal.
roymck
Has thanked: 15 times
Been thanked: 24 times
Post by roymck » Fri Apr 12, 2019 1:11 pm
Running a Hot rod without mudguards is not a MOT fail,but is against construction and use regs . It’s all a nightmare
Post by scimjim » Fri Apr 12, 2019 2:37 pm
Yes, an MOT test isn't as stringent as the C&U regs it's based on (or it would take 5 hours like an IVA) but it's hardly a nightmare - it's all quite clearly documented!
An MOT is an annual test to confirm a vehicle meets the minimum requirements of safety, roadworthiness and exhaust emissions required in the United Kingdom.
Has thanked: 340 times
Been thanked: 275 times
Post by CNHSS1 » Fri Apr 12, 2019 6:23 pm
Saw a BMW X1 with NA55 TAY... I didnt stop to enquire as to whether the driver was nasty or not...
