How to fit a larger battery
ard126k
Been thanked: 27 times
Post by ard126k » Sun Feb 03, 2013 10:49 pm
I've thought for a long time that the usual 038 or 049 battery fitted to Scimitars is only just big enough for the job, so I decided to see if a larger one could be squeezed in. Measuring around the battery tray and looking at http://www.tayna.co.uk/car-battery-wizard.php I decided on an 072 size. Some bodywork was needed - this shows how I cut the inner side of the battery box -
and a small hole in the wheelarch -
I turned the box side upside down and fixed it in place ready for glassing in..
This was a 6a, I've now also done a 5 so I'll post photos soon.
Alex.
1971 SE5 1977 SE6 1982 GTC
windy
Been thanked: 41 times
Re: How to fit a larger battery
Post by windy » Sun Feb 03, 2013 10:53 pm
Thats ingenious, and a much better job than cutting the front out as most do.
ard126k
Post by ard126k » Sun Feb 03, 2013 10:56 pm
So this is the same job done on an SE5,at the primer stage. I didn't turn over the side for this one, which made the GRP work a bit harder underneath but left a neat lip along the top edge where it matters!
I've driven both cars now and no problems with wheels fouling the inner arch. Wonder why RMC didn't do it this way?
Alex.
MikeT
Has thanked: 21 times
Been thanked: 23 times
Post by MikeT » Mon Feb 04, 2013 8:22 am
That's very neat - nice work.
Mine's had the front chopped out in the past - while it's functional, it doesn't look as 'factory' as that.
Well done.
Mike.
manny
Has thanked: 35 times
Post by manny » Tue Feb 05, 2013 12:58 pm
just wandered..any one got a dual battery setup, either side of the engine? would the charging circuit complain?
tony.idle
Been thanked: 56 times
Post by tony.idle » Tue Feb 05, 2013 1:30 pm
The charging circuit wouldn't notice the change.
Tony
RSSOC 2332 since 1981
Has thanked: 146 times
Been thanked: 1026 times
Post by scimjim » Tue Feb 05, 2013 1:32 pm
Do you mean two 6v batteries (as per original coupe) or a leisure battery on a split charger (to run an x-box in the passenger seat - how chav :-)) or a second starter battery?
And why? :-)
Has thanked: 67 times
Been thanked: 659 times
Post by philhoward » Tue Feb 05, 2013 1:37 pm
Or 2x34Ah normaly batteries = the same grunt as a 68Ah battery?
Has thanked: 32 times
Been thanked: 49 times
Post by nickkeyser » Tue Feb 05, 2013 1:39 pm
scimjim wrote:And why? :-)
I was wondering this. Why do you need a bigger / second battery?
trubac
Post by trubac » Tue Feb 05, 2013 6:31 pm
Alex, which tool did you use to do the cutting ?
very neat ! congrat !
Se5a '75 (Sold)
Jensen Healey '73
Triumph 1300 TC '68, Herald '66
Honda C90 '71
Lambretta Li '64
Lambretta LD '53
RSSOC #1767
manny
Post by manny » Tue Feb 05, 2013 8:42 pm
just wandered if some folks are running HC engines, my tr7 V8 had the battery moved to the boot, partly i guess because the proper TR8 required a bigger battery to handle the cranking power( ..heat as well maybe)...i have no need ( for chav points...now) just wandered.
Ta
Manny
manny
Post by manny » Tue Feb 05, 2013 8:49 pm
also the topic kinda lead me that way "How to fit a larger battery"...why not fit two either side..if possible without hacking the bodywork, BTW no dig at ALEX...that looks wicked..
ard126k
Post by ard126k » Fri Feb 08, 2013 1:15 am
I didn't see how a battery either side would leave room for the spare wheel. And the cost of two would be more than the 072 I'm using.
And why? Looking at sites which give recommended battery sizes for 3L Essex-engined cars you'll see most specify batteries with more CCA ( cold cranking amps) than the normal Scimitar size. BTW the AH (amp-hour rating isn't about the 'grunt' of a battery, but about how long it will keep the lights (say) on.
Alex.
ard126k
Post by ard126k » Mon Feb 06, 2017 9:56 pm
I've just found a downside to this job - I can't get the crossbrace in front of the engine out without taking the radiator hoses off! On the SE5 anyway, don' know about the 6a.
On the upside the 072 battery is still going strong, it's lasted much longer than the little ones did. I guess it's having an easier life than they did cranking the Essex.
Alex.
