Corky's Scimitars & S2K
td99
Been thanked: 25 times
Corky's Scimitars (..and now an SS1 race car build)
Post by td99 » Thu Oct 26, 2017 6:44 pm
Nice touch with the speedo cable Steve :) :)
(Wish I'd should have thought of that, but can still make that mod if necessary).
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Has thanked: 188 times
Been thanked: 188 times
Post by Corky » Thu Oct 26, 2017 7:56 pm
Thanks Trevor. I had the same problem on the Sabre, but decided to run the speedo cable under the carpet. I’m hoping this will be a better solution.
Post by Corky » Sat Oct 28, 2017 5:14 pm
The Lotus seat arrived......
....and it fits the space really well. Trouble is, I just think it's too small for me. The MR2 seat feels like a better solution, as it has a height adjuster and it reclines. Meaning that I can get properly comfortable, and it'll adjust easily for other drivers. Not only that, but it'll take the seatbelt clip as per the original. We're still heading towards RG with this car for 2018.
So we're going with this:-
It's not yet bolted in. I need to secure some eye bolts to the chassis for the harness, then I can get it bolted down.
If anyone wants a Lotus Elise seat for £100, drop me a PM. They're about £250+ each on eBay... form an orderly queue :wink:
Post by Corky » Tue Nov 14, 2017 5:26 pm
Not much has progressed on the car over the last couple of weeks.
I finally got the MR2 seat rails trimmed and drilled to fit the new cross-members. Whilst I was at it I created a recess in the square tube so that the bolts were not exposed below the rails. The seat is now bolted into place, and I'm pleased to say the MR2 seat is pretty much perfect. The main benefit is that the seat base raises and lowers, which will be handy when changing between shorter and taller drivers.
Socket sized hole to allow access to the recessed seat bolt. The steel is thicker than the U section that Reliant used, so this seemed sensible. It'll be sealed with a grommet eventually.
M8 mounting bolts secured in the MR2 seat rails.
In place
Doesn't touch the door. I was worried it may be too wide.
Next up. I fitted the rear end of the cage, and mocked up the fuel tank. (I need to get the filler hose a touch higher)
Filled the gaps around the back stays by taping card to the underside of the parcel shelf and filling the gaps with chopped strand.
That's it for now. I may yet have a fuel tank made rather than using this one, still undecided........
Post by Corky » Tue Nov 21, 2017 5:12 pm
Beginning to look a little bit more car like....
Post by gtcse8 » Tue Nov 21, 2017 5:30 pm
Nice and shiny Istrian Blue
Has thanked: 108 times
Been thanked: 69 times
Post by efi_sprintgte » Tue Nov 21, 2017 6:41 pm
Good work Corky!!
Post by Corky » Tue Nov 21, 2017 6:51 pm
It was either going to be blue or white :lol: It just so happened that RR had a set of shiny blue panels available.
Good work Corky!!
Thanks James, lots still to do. Next go-faster job will be fitting the intercooler :mrgreen:
Post by efi_sprintgte » Tue Nov 21, 2017 6:53 pm
oh man, now RR has only got left 3 spare body shells worth of panels for KMG... :P
Has thanked: 87 times
Been thanked: 134 times
Post by reliant-reviver » Tue Nov 21, 2017 7:10 pm
Only panels with patina for my car. Currently storing empty boxes on it.
Mr Cork is again making a shiny race car that will be too nice to abuse.
Post by reliant-reviver » Tue Nov 21, 2017 7:11 pm
I'm glad to see them being put on something though. No use in my loft were they.
Post by Corky » Sat Dec 02, 2017 5:46 pm
Slow progress, but getting things done. The back end is now rebuilt and the small tank installed. I've yet to fit the swirl pot as I'm having thoughts of a custom tank :roll:
I've fitted the glass to the hard top and fitted the front wings and new indicators and wiring. I also had to fit the heater blower hose flange to the new wing and fit a new length of flexi hose (100mm ducting from screw fix..).
Spot the new LED number plate lamps, same as I fitted to the Sabre.
I now need to remove this trim piece from the hard topand fit something that'll push over and cover the holes.
Next steps will be fitting and building up the doors, fitting an MR2 seat to the passenger side, fitting the intercooler, taking it for a custom exhaust......
Post by Scimher » Sun Dec 03, 2017 9:12 am
Great work, Steve...
Post by Corky » Tue Dec 05, 2017 5:13 pm
Thanks Geoff.
I've now got both doors on, and have almost finished building them up. The locking mechanisms are right PITA, it took me 8 hrs to hang two doors, fit them out and get the locks and catches functioning correctly. Just got the quarter lights and glass to fit when the paint dries :D .
The inside of the doors look like this, so unless modified, they need an early style door card.
The door cards I have look this (later type). They have been butchered by a PO to allow access to the door locking mechanisms. I could probably make them look a bit nicer, but if anyone has any better ones going spare, please give me a shout.
Has thanked: 50 times
Been thanked: 599 times
Post by philhoward » Tue Dec 05, 2017 5:20 pm
Knock up some infill panels akin to the earlier type to fill the recess? Maybe a nice red to match the seats?
