tell me about your trailers?
For discussion about any other Motorsport Discipline (Drag Racing, etc).
Moderators: scimjim, philhoward, Lukeyboy46, erikscimitardemon, Roger Pennington, nickkeyser
Has thanked: 331 times
Been thanked: 265 times
Post by CNHSS1 » Sun Nov 15, 2015 8:04 pm
Im due to move house on friday and new house has a nice large garage but have just measured up the garage door and its only 7ft wide so my 92" trailer wont go in! Bugger...
By altering the door frame i can get to 88" max
So i need a trailer to suit my Sabre, ideally a 6'1" bed but narrow enough to go into the garage. Ive checked and both garage doors are same width :-(
Current Brian James Tiltbed will have to go but what do i buy??
To be honest the tiltbeds lovely, no fannying with ramps but ramps are no biggie really.
Ive only had Brian James (Minno and Clubman tiltbed) and a home built (not by me). The BJT tow so well in any conditions and at any speed *cough* but am happy to look at Woodford, PRG etc. Must be a motorsport style trailer, low bed, dont want some digger trailer with a high C of G.
Your thoughts please Chaps and overall widths of your trailers?
Has thanked: 33 times
Been thanked: 92 times
Re: tell me about your trailers?
Post by swoakes » Sun Nov 15, 2015 9:01 pm
I'm very happy with mine but they have phased out the model I have now so not sure any measurements will help.
I couldn't get a trailer small enough to fit in my garage so I went for a bigger trailer that could carry whatever I wanted it too (tow car permitting :wink: )
Corky has his in the garage BUT his is a double door garage
Post by CNHSS1 » Sun Nov 15, 2015 9:11 pm
What makes yours Steve? If i can pick up the ideal model used id go for that or if not go for new.
New garage will sit 3 x cars side by side but has two 'normal' doors, cant believe it never even dawned on me!!
Has thanked: 188 times
Been thanked: 188 times
Post by Corky » Sun Nov 15, 2015 9:27 pm
Both Steve's and mine are the same model, but different sizes. Mine would fit into a single a garage. It takes up roughly the same footprint as the Audi.
Have a look at this link http://www.southerntrailers.co.uk/trail ... sA-Max.pdf . Mine is the 120-1100 model IIRC.
It'll just about take a 5a, but a 6A/GTC is pushing it a bit.
Post by swoakes » Sun Nov 15, 2015 9:43 pm
Yours would have fitted in my garage Steve but would not go through the door :? :roll:
As Steve says mine is bigger the A-max 120-3050
Mine is 95.5 inches at its widest point which is where the reflectors stick out at the rear
Post by CNHSS1 » Sun Nov 15, 2015 9:50 pm
Cheers Chaps. It looks as if Steve Cs spec would work, so will take some measurements and give BJT a call i think
scimmy_man
Been thanked: 34 times
Post by scimmy_man » Mon Nov 16, 2015 9:28 am
rather than swap trailers, can you make the door wider, it would make life easier.
Been thanked: 90 times
Post by Coupe Racing » Mon Nov 16, 2015 10:17 am
Surely a new door is cheaper than a trailer :D :D :D
My PRG is way too wide
Post by CNHSS1 » Mon Nov 16, 2015 11:35 am
Garage is 3 car but has 2 x 'normal' doors. Doors are 7ft wide with 2" frame either side.
I can cut bottom of frame off and attach to door to give me 88" brickwork to brickwork.
Ultimately i can modify brickwork but cost and hassle wise, its easier to swap the trailer. I will have enough on the house 'To do' list without surgery to tye walls :lol:
red rocket
Been thanked: 11 times
Post by red rocket » Mon Nov 16, 2015 11:42 am
I need a larger trailer ideally - I bought mine to fit into a single garage and no longer need to do that. Perhaps we could have a chat?
I only ride 'em - I dunno what makes them work
Post by CNHSS1 » Mon Nov 16, 2015 12:19 pm
Now you are talking :-)
Will PM numbers
Cheers Craig
Post by Coupe Racing » Mon Nov 16, 2015 2:07 pm
My doors fit behind the brickwork
Any way was only pulling your leg mate
Post by CNHSS1 » Mon Nov 16, 2015 3:11 pm
No worries, all ideas gratefully rec'd :-)
Return to “Other Motorsport Discussion”
