Best rim size for Race SE5?
collin
Post by collin » Wed May 02, 2018 6:55 am
Hi.
I'm looking to specify a set of 7 x15'' Minilite style alloy rims for my car as they would appear to be an optimum size to fit within the arches if I can work out the correct offset etc
8 x 15's would seem a step too far and foul the arches.
Any advice would be welcome as the wheel manufacturers/retailers are not too helpful these days
Been thanked: 840 times
Post by scimjim » Sun May 06, 2018 9:43 pm
Welcome :D
Standard wheel sizes are given in this thread, so you should be able to get a rough idea of offset using a site like www.willtheyfit.com
I think 8x15 have been fitted with spacers to standard arches but it will be very close and can depend on the tyre a lot (size and tyrewall strength)?
Been thanked: 62 times
Post by BigBobPilot » Sun May 06, 2018 10:26 pm
If it's for racing are there any limitations in the regs for your chosen series? For example, in the CSCC swinging sixties, you need to use a minimum 60 profile tyre. If you have 60 profile tyres on a 15" wheel, it's quite tall and lifts the car ride height, so 14" wheel is a better fit. If you can go to 50 or 55 profile then the 15" works ok.
SS1 CA18DET race car in build
turbster
Post by turbster » Sun May 06, 2018 10:57 pm
If you want 7x15 you need around -10mm offset, 8” is too big for standard arches, and I found 7x14 were best for racing in 60 profile as mentioned above..
LRP 335E SE4a
XRF 976H SE5
DBY 119M SE5a
Dcrosby13
Post by Dcrosby13 » Mon May 07, 2018 12:25 am
I went with these, it seems quite a few competition cars have them:
ImageIMG_20180417_111603 by Darryl Crosby, on Flickr
I break stuff...... :w
Return to “General Circuit Racing Chat”
