Overheat
Been thanked: 842 times
Overheat
Post by scimjim » Fri Mar 24, 2017 4:29 pm
Here's a message I've never seen before!
Had to resort to the 60" smart TV (not mine, in a friends house that we're staying in)
Been thanked: 86 times
Re: Overheat
Post by Coupe Racing » Fri Mar 24, 2017 9:00 pm
Yep an iPhone will notify if it gets too hot or too cold
Often rapid charging can make the phone hot
Been thanked: 321 times
Re: Overheat
Post by peter freeman » Fri Mar 24, 2017 10:08 pm
Battery gets hot - warps - the plates touch shorting out - current maximises creating more heat - bang
Re: Overheat
Post by scimjim » Sat Mar 25, 2017 12:49 am
Are there plates in an iPhone battery?
About 28deg in the garden when that message came up :-)
Been thanked: 535 times
Re: Overheat
Post by philhoward » Sat Mar 25, 2017 3:28 am
I've had that message with an iPod touch when in India but it was high 30's there.
Re: Overheat
Post by peter freeman » Sat Mar 25, 2017 9:21 am
scimjim wrote:Are there plates in an iPhone battery?
Apparently yes but probably not the conventional plates you think of.
Re: Overheat
Post by peter freeman » Sat Mar 25, 2017 9:40 am
I knew I had read about it not too long ago.
phone bats.jpg (135.9 KiB) Viewed 2825 times
Revingtosh
Re: Overheat
Post by Revingtosh » Wed Apr 12, 2017 5:57 pm
I fix a lot of ipads - this is just a self protection mechanism
Re: Overheat
Post by scimjim » Wed Apr 12, 2017 6:05 pm
Revingtosh wrote:I fix a lot of ipads - this is just a self protection mechanism
It was a bit tongue in cheek - I was in Barbados 8)
MoneyHannah
Re: Overheat
Post by MoneyHannah » Wed Apr 19, 2017 11:49 am
Exactly the same thing appeared on my screen last summer. Turns out an iPhone shouldn't be exposed to direct sunlight for too long. Luckily, it didn't explode or melt ^^
demonbluedays
Re: Overheat
Post by demonbluedays » Mon May 22, 2017 3:11 pm
Having repaired these several times (sorry for reviving an old thread) but iPhone and Samsung batteries are swines for swelling slightly, and then heat up like all hell when you try to charge them or ask the phone to do anything memory/processor/Gpu taxing, usual simple fix is replacement battery, common cause for it, and I know you lot are possible guilty is charging overnight, having seen a live demonstration of both companies various batteries "letting go" (boom) it's amazing just how hot they get....
Tom "DemonBlueDays" Williams
1976 SE6 #141 "Mighty"
2009 Fox "King"
Former Owner Of
