You tube video links
Has thanked: 25 times
Been thanked: 86 times
Post by swoakes » Fri Mar 17, 2017 4:57 pm
All new and past You tube video links in threads are just showing as white rectangles.
I'm still running Vista home premium edition and Chrome.
Is it likely to be a driver/ update issue :?:
Any ideas :?:
td99
Been thanked: 22 times
Re: You tube video links
Post by td99 » Fri Mar 17, 2017 7:20 pm
Regardless of cause of the problem, try upgrading to Win 10. Even if it costs you money, the improvement will be worth it, provided of course that you have compatible hardware - which you can check out first.
If you want to continue with vista your problems will only increase....
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Post by swoakes » Fri Mar 17, 2017 7:25 pm
My laptops quite old. I think it may be due to the fact that Chrome no longer supports my flavour of Windows and the Flash plugin used by You Tube is old.
Just checked and I can upgrade to Windows 7 ok.
I think I may just go for a new machine so that I can keep the old running whilst I sort out the new :wink:
tony.idle
Been thanked: 55 times
Post by tony.idle » Fri Mar 17, 2017 7:36 pm
A small point unknown to many: search for free download W10 then choose the Microsoft site for the download. You need to tick a box to say you have accessibility problems then you can have an up-to-date download of W10 FOC.
Tony
RSSOC 2332 since 1981
Been thanked: 876 times
Post by scimjim » Fri Mar 17, 2017 8:27 pm
I reposted a YouTube vid for Steve this morning (Ti first start) and it showed fine? I also copied the address from one of your YouTube videos in the compie section which displayed fine.
Post by swoakes » Fri Mar 17, 2017 10:17 pm
scimjim wrote:I reposted a YouTube vid for Steve this morning (Ti first start) and it showed fine? I also copied the address from one of your YouTube videos in the compie section which displayed fine.
Yes Steve's first start vid was what brought the issue up Jim, I think my flavour of windows is just too old and not supported by chrome. Looks like the plugin has stopped working so a new laptop may be in order :wink:
Post by scimjim » Sat Mar 18, 2017 12:09 am
Ah - perhaps this should be in computer problems rather than forum issues then?
Post by swoakes » Sat Mar 18, 2017 9:11 am
scimjim wrote:Ah - perhaps this should be in computer problems rather than forum issues then?
Yes agreed
erikscimitardemon
Post by erikscimitardemon » Sat Mar 18, 2017 10:29 am
Now moved to the proper subforum :D
Erik Hofman
http://www.scimitar.demon.nl
Post by swoakes » Mon Mar 27, 2017 2:58 pm
I am now able to view the forum via my Windows Vista PC (has Ian resolved security issue or is this a fluke :?: )
You tube embedded links still show as blank rectangles to me though :(
Post by scimjim » Mon Mar 27, 2017 3:27 pm
Are you viewing the forum via http or https?
Post by scimjim » Mon Mar 27, 2017 3:50 pm
When I copied the link from this video (and posted on FB where it shows perfectly), the address was https but when I pasted it here it won't work unless I change it to http. If I view the forum via http it shows fine but if I go to https://scimitarweb it is just a blank
Post by swoakes » Mon Mar 27, 2017 4:02 pm
scimjim wrote:Are you viewing the forum via http or https?
No idea
I'm using the same bookmark that I've always used. URL is www.scimitarweb.co.uk
I don't have http or https in the address bar
Post by scimjim » Mon Mar 27, 2017 4:06 pm
I don't have it on the iPad either. Type it in manually to force it to change.
Post by swoakes » Mon Mar 27, 2017 4:11 pm
scimjim wrote:I don't have it on the iPad either. Type it in manually to force it to change.
typing http:// before the url makes no difference to my ability to view you tube links.....they are still blank rectangles on my laptop running Visata
