BIOS sorted
Been thanked: 86 times
BIOS sorted
Post by Coupe Racing » Tue Jan 03, 2017 5:07 pm
Well - I just cant get into my BIOS
The manual says F2 on start up , and that used to work
Now it doesnt :shock:
I need access to set the boot order so I can run Windows 7 from the DVD and install onto a newly formatted small hard drive.
( I was going to run 2 operating systems on the same machine , and choose which hard drive I wanted at boot up - long story as to why )
So this problem came about as a result of me installing a spare hard drive into my good machine , then booting my pc with Windows XP on my 500GB hard drive as a master , and a spare 60GB that was set to a slave in the same machine.
Whilst in this state , I formatted the small hard drive and now my BIOS is inaccessible
I have visited the motherboard website , and found the original BIOS file , and loaded it per their instructions , but every time I boot up - F2 fails and XP goes ahead and loads regardless off of the large drive ( the small drive is not fitted anymore - it was only temporary )
Any help would be apprciated please !
Been thanked: 113 times
Re: BIOS
Post by ScimmyMike » Tue Jan 03, 2017 5:28 pm
Steve, what pc model is it, sometimes you can hit a key and alter boot order as a one off rather than going through BIOS to change then again to change back
Re: BIOS
Post by Coupe Racing » Tue Jan 03, 2017 5:34 pm
Sorted
Plugged the USB keyboard into a port on the mother board and not the extra port on a PCI card
Terry H
Been thanked: 42 times
Re: BIOS sorted
Post by Terry H » Tue Jan 03, 2017 5:41 pm
Press and hold the delete key on start up.
Regards Terry H
1185
td99
Been thanked: 22 times
Re: BIOS sorted
Post by td99 » Tue Jan 03, 2017 6:00 pm
If you want to have an easy choice of booting from disk 1 or disk 2 etc, look at Easy BCD (its free!)
And its companion iReboot enables you to click on menu in system 1 and it reboots to system 2 and vice versa.
Can also set default system to boot if no choice made after user-definable time, eg 5 secs.
No need to enter BIOS to set boot disk!
Marvelous bit of kit!
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Re: BIOS sorted - Boot help required
Post by Coupe Racing » Sun Jan 08, 2017 2:42 pm
I tried the software - but iReboot just keeps booting into XP , and I dont understand EasyBCD at all
I have attached a picture , but dont know what to do.
I just want an option at start up to choose between HHD
Any ideas please
td99
Re: BIOS sorted
Post by td99 » Sun Jan 08, 2017 4:11 pm
Does the EasyBCD menu work? ie, do you get a menu with two options at start-up?
if so, can you boot into both XP and W7?
(Bit surprised at the bootloader path for win 7, but if it works ok).
if not open easybcd and edit boot menu
check that "Skip boot menu" is not selected.
If you can boot to either system from EasyBCD menu, then when you are in XP, open the iReboot icon and change the selection there to Win 7 and all should work OK.
ireboot is not essential, just handy!
Hope that helps.
