Window size
- Coupe Racing
- RSSOC Member
- Has thanked: 14 times
- Been thanked: 87 times
Window size
Using XP - I like it so dont ask me to change
Using IE 8 - I like that too
My window opens in a size which is less than the screen - and Im tired of stretching it to fit.
I have tried stretching , then closing the tab , but XP does not seem to remember the last size or position
Any pointers please
Any pointers please
- philhoward
- RSSOC Member
- Has thanked: 43 times
- Been thanked: 540 times
- Contact:
Re: Window size
I seem to recall a trick where you press the shift key when you close it down (red X)?
Edit: after making it full size, of course. I think a double click on the top bar makes it maximum size?
- toomanysabres
- RIP
- Been thanked: 88 times
Re: Window size
Yep just tried that with this. A second d.click puts it backphilhoward wrote:I seem to recall a trick where you press the shift key when you close it down (red X)?
- Been thanked: 13 times
Re: Window size
Hello Coupe Racing,
try this:- right click on the IE shortcut, then click options which should open a small window with tabs, click on the shortcut tab (If not already open) then lower down there is a menu box labelled 'Run:' click on the menu arrow which then gives three options, so click on 'Maximised' then 'Apply' and 'OK'.
Hopefully this will sort it ?
Alec
Alec
1968 Triumph 2.5 P.I., Jaguar X Type estate 2.5, 1962 Jaguar MK 2, very long term restoration. 1991 Hymer 564 motorhome
- Coupe Racing
- RSSOC Member
Re: Window size
to date - neither solution has worked
Re: Window size
Hello Coupe Racing,
I can see that I put options when it should have been properties, sorry. The rest should be as I said.
Alec
Alec
- Coupe Racing
- RSSOC Member
Re: Window size
OK - tried the suggestion and Im afraid the issue remains
I suspect a registry issue
Re: Window size
Hello Coupe Racing,
would you expand a bit, were you able to set the 'Run' window to 'Maximised, and did you click 'Apply' and 'OK' after? If you now right click on the IE shortcut and then click 'Options' does the 'Run' window still have 'Maximised'? If it has then my knowledge doesn't extend further.
Alec
Alec
- Coupe Racing
- RSSOC Member
Re: Window size
I can confirm all of the above is correct but the problem still exists Im afraid
- peter freeman
- RSSOC Member
- Has thanked: 9 times
- Been thanked: 326 times
- Contact:
- Coupe Racing
- RSSOC Member
Re: Window size
Monitor is fine
