No mobile single can I use fibre for a mobile.
philynnbob
Has thanked: 64 times
Post by philynnbob » Thu Apr 02, 2015 2:54 pm
Hi
Hoping that some of you can provide an answer to a problem I have at my home location.
I am not very up on technical info re Internet etc. ( retired person)
Hope this is a simple query for those in the know.
In the village where I live there is no mobile phone single of any description, however we are just about to have superfast fibre optic broardband in to the village.
My question is twofold-
one,will I be able to use a mobile phone at home via my wireless modem/box?
Two,Will I also be able to use same mobile away from my home location?
Thanks in advance Phil
MikeT
Been thanked: 23 times
Re: No mobile single can I use fibre for a mobile.
Post by MikeT » Thu Apr 02, 2015 3:08 pm
Phil - Regarding your first problem... when we have this problem at work with home workers, we've used this kind of thing in the past -
http://shop.vodafone.co.uk/shop/mobile- ... 5375-white
You register your mobile with it, and it enables the mobile to see the mobile network. Because you've only register your phone(s) with it, your neighbours won't be able to benefit from it (unless you want them to, of course).
This one works with Vodafone mobiles - I'm guessing the other providers do a similar thing though.
This would only give you coverage local to your house really.
HTH.
Mike.
Been thanked: 534 times
Post by philhoward » Thu Apr 02, 2015 3:14 pm
When I had a Blackberry, their service jumps onto a Wifi signal to route back to the mobile network (called UMA) which was handy for me as I lived in a poor mobile reception area but had good broadband. Upshot was I could use my phone abroad using free hotel wifi as if I was at home.
Vodafone suresignal is a very similar setup I believe?
scimmy_man
Been thanked: 32 times
Post by scimmy_man » Thu Apr 02, 2015 5:10 pm
we have the opposite problem,
0.4mbps broadband, but we get good 3g or even 4g coverage, gone over to an EE mobile modem wifi, getting up to 43mbps.
scimmy ben
Post by scimmy ben » Thu Apr 02, 2015 5:36 pm
If you are with (or going to be) Vodafone- see Mike T's solution
If on O2 you will need the TU GO app - I use the abroad with a local SIM to 'stay' in the UK
Chgperformance
Post by Chgperformance » Thu Apr 02, 2015 5:41 pm
If you are with three, ring up and complain about signal twice, then you get the booster for free :D
philynnbob
Post by philynnbob » Fri Apr 03, 2015 11:38 am
Right Chaps, many thanks.
From your replys I now have a much clearer picture ( did think that as it is BT fibre network then it would need to be a bt mobile phone)
Realised now it can be a mobile contract with any network .
If any of you ever require a front loading alcohol detox please feel free to drop me a line :D
Cheers Phil
scimmy_man
Post by scimmy_man » Fri Apr 03, 2015 3:48 pm
if I knew what it was .....................
