Complete Novice
Moderators: scimjim, philhoward, Lukeyboy46, erikscimitardemon, Roger Pennington, nickkeyser
AndyM
Complete Novice
Post by AndyM » Mon Feb 19, 2018 3:18 pm
swoakes wrote:
Mon Feb 19, 2018 2:50 pm
AndyM wrote:
Mon Feb 19, 2018 2:38 pm
Could one of these also work at the back around a section of chassis?
https://www.ebay.co.uk/itm/Motorsport-H ... 1438.l2649
The steelwork behind the rear bumper on an SS1 is pretty thin and would not take much of a pull to pull it out of shape. Some have beefed this up by inserting a section of steel to the chassis below the tank I think linking the two together. I took the view that this was lots more work than what I did which was easy and cheap to achieve even by an amateur like me :wink:
Looking at your Pics, I think your solution is easier. Did that towing eye screw straight in?
Has thanked: 33 times
Been thanked: 92 times
Complete Novice
Post by swoakes » Mon Feb 19, 2018 3:29 pm
The loop bit of the eye had an M12 thread into which I put a length of M12 bar. The other end of the bar goes through the diff hole with nuts and washers either side and all tightened up to secure it.
Simply loop the lifting strap through the eye and run the other end to the corner of the bumper securing with tie wraps. The wraps simply keep it all in place so that its all neat and hanging under the bumper. I used the lightest wraps I could get away with so that when the car is towed they just snap without causing any damage to the car. Never been used in anger yet :wink:
Complete Novice
Post by swoakes » Mon Feb 19, 2018 3:32 pm
This is the eye. The bit that screws into the loop is M12
https://www.ebay.co.uk/itm/European-Mod ... Z4B4ke6qaw
This is the type of sling I used. Mine was 3 tonne but 1 would do the job
https://www.ebay.co.uk/itm/Flat-Webbing ... 5l_A78l-VA
AndyM
Complete Novice
Post by AndyM » Mon Feb 19, 2018 3:48 pm
Thanks Steve, I really appreciate all the help.
There's a lot to think of first time out! This time next year should be easy....
Complete Novice
Post by swoakes » Mon Feb 19, 2018 3:57 pm
No problem. It was just the same for me when I started :wink:
AndyM
Complete Novice
Post by AndyM » Tue Feb 20, 2018 12:11 pm
Well that's Gurston, Prescott and Shelsley Walsh Booked! Expensive morning!
I have only booked the Sunday at Gurston at the moment as I feel that a two dayer to start with may be a baptism of fire!
Any others of the following need early booking?
Abingdon
Castle Combe
Curborough
Wiscome
Has thanked: 87 times
Been thanked: 134 times
Complete Novice
Post by reliant-reviver » Tue Feb 20, 2018 1:14 pm
Question, are you signed up to a suitable championship, I may have overlooked this if you have already, but can't help but notice you aren't on the classic marques list.
Re the tow point. I did as per Swoakes, substantial eye in the diff casing and a 1 tonne (3 tonne breaking limit iirc) 1M strap through this and tied up with a zip tie to a P clip on the rear bumper lower fixing.
Complete Novice
Post by swoakes » Tue Feb 20, 2018 1:20 pm
You are on the list Andy (Andrew Mawbey yes?)
Complete Novice
Post by reliant-reviver » Tue Feb 20, 2018 1:46 pm
Right you are, hadn't spotted the latest list.
No room at the inn for any more though by the look of it. Have fun, do the sword badge proud!
AndyM
Complete Novice
Post by AndyM » Tue Feb 20, 2018 1:54 pm
Yes, I am officially Andrew to CM and my mother!
Complete Novice
Post by swoakes » Tue Feb 20, 2018 2:02 pm
They have a strong FB page https://www.facebook.com/groups/Classicmarques/
Suggest you ask to join if you are a FB user :wink:
List below copied and pasted from today's posted list
List below
110 Paul Jaggard Alfa Romeo ??
79 Nigel Varney Alfa Romeo Giulia Coupe
86 Lloyd Jones Fiat Abarth
10 Phil Jones Fiat Abarth
45 Jonathan Plowe Fiat X1/9
99 John Brunner Ginetta G20
40 Rob Pallett Ginetta G20
20 Graham Beale Ginetta G33
46 Matthew Eady Ginetta G4
43 Roger Coote Ginetta G4
35 Stephen Casson Healey Sebring Sprite
62 Les Procter Healey Sprite
88 Martin Rowe Honda S2000
67 Phil Ludbrook Honda S2000
90 Roger Fish Honda S2000
14 Paul Slade Jaguar E Type
74 Matt Tobutt Lotus Elan +2
127 Gary Dawkins Lotus Exige
102 Steve Hill Lotus Lotus 7 Ser 2
104 Ben Everett Mazda MX5
115 Chris Harris Mazda MX5
21 Mark Everett Mazda MX5
69 Merv Brake Mazda MX5
120 Sandy Smith Mazda MX5
103 John Pollard Mazda MX5 - NC
89 Howard Barnard Mazda MX5 - Sup
100 Tom Barnard Mazda MX5 - Sup
117 John Wadsworth Mazda MX5 Mk 3
145 Kiron Phillips Mazda MX5 T
146 Zanesh Phillips Mazda MX5 T
51 Mike Cole MG B GT
30 Richard Withers MG B GT
38 Rob Orford MG B Roadster
52 Ian Beningfield MG Midget
121 Jamie Fisher-Pearson MG Midget
81 John Payne MG Midget
137 Clive Glass Morgan +8
132 Nick Bolton Morgan +8
125 Rob Toon Morgan +8
140 John Stephens Morgan 4/4
124 Simon Ashby Morgan 4/4
138 Paul Clarke Morgan Roadster
133 Simon Baines Morgan Roadster
139 George Proudfoot Morgan Series 1
91 Jonathan Cole Morris Mini
128 Nigel Watkins Porsche 911 (996)
142 Gordon Weston Porsche 924S
34 Brian Marshall Porsche 944 Turbo
136 Simon Smith Porsche Boxster
134 Peter Taylor Porsche Boxster S
85 Steve Lyle Porsche Boxster S
113 Gordon Pearce Porsche Cayman
73 Paul Turnbull Scimitar GT
144 Richard Carter Scimitar GT Coupe
143 James Carter Scimitar GTE
49 Stephen Oakes Scimitar S1
50 Steve Cork Scimitar S1
57 Craig Hughes Scimitar Sabre Turbo
135 Dave Greenhalgh Scimitar SE5
141 Andrew Mawbey Scimitar SS1
122 Ben Curry Scimitar SS1
131 Jim King Scimitar SS1
95 Josh Oakes Scimitar SS1
96 Nick Keyser Scimitar SS1
118 Peter Smith Scimitar SS1
71 Peter Owles Sunbeam Tiger
2 Trevor McMaster Toyota MR2 Mk3
119 Nick Hall Toyota MR2 T Bar
116 Robert Macgregor Triumph Dolomite Sprint
106 Tony Browne Triumph Dolomite Sprint
109 Bob Barnard Triumph TR4
107 Samantha Browne Triumph TR4
130 Dale Strachan Triumph TR6
8 Nick Smith Triumph TR6
39 Roderick Warner Triumph TR7 V8
126 Steve Small Triumph TR7 V8
37 Mark Harris TVR Cerbera 4.2
129 Richard Bream TVR Chimaera 450 Sup
19 Jes Firth TVR Griff 500
82 Alan Hugh Davies TVR Griffith 4.3
123 Dave Morris TVR Race Tuscan
6 Steve Cox TVR V8S
AndyM
Complete Novice
Post by AndyM » Fri Feb 23, 2018 11:18 am
Bits have arrived!
Complete Novice
Post by swoakes » Fri Feb 23, 2018 11:19 am
8)
AndyM
Complete Novice
Post by AndyM » Tue Feb 27, 2018 2:55 pm
Fire Extinguisher?
Do I need one for events; if so what size and I presume dry powder?
I carry one in the boot day to day, but does it need to be secured somewhere in the cockpit?
Has thanked: 188 times
Been thanked: 188 times
Complete Novice
Post by Corky » Tue Feb 27, 2018 3:03 pm
You don’t need one in RG but it is recommended. Foam is the way to go not DP.
