Complete Novice
Has thanked: 22 times
Been thanked: 83 times
Complete Novice
Post by swoakes » Sun Feb 18, 2018 9:42 am
AndyM wrote:
Sat Feb 17, 2018 11:31 pm
scimjim wrote:
Sat Feb 17, 2018 3:42 pm
I’ve fitted a single skinned hardtop - better aero and lighter than the soft top & frame.
I managed to pick up a hard top for mine last year but am not sure if I need fixings? I will take a look at how they fit at curborough on the 20th if others have theirs on.
Fitted by 2 levers at the leading edge and 2 bolts between the brackets on the hardtop and the hole in the B pillar mounted bracket on the car.
I'll take a photo of mine when I can. The hard top is the way to do go IMHO :wink:
Complete Novice
Post by swoakes » Sun Feb 18, 2018 1:50 pm
This is the hardtop fixing at B post. Large slotted bolt screws into the bracket. The bolt has a strange course thread from memory.
Complete Novice
Post by Oaksey » Sun Feb 18, 2018 2:04 pm
I didn't realise that was your car ;)
AndyM
Complete Novice
Post by AndyM » Sun Feb 18, 2018 3:17 pm
Thanks for the pic. Mine has the slotted bolts and the roof has the bracket on already, my only issue may be the roll bar. I have one of the new ones from the club that is bolted to the same point. I will have to dig it out of the shed and see if it fits. It’s a bit tatty with 1980s black vinyl but fingers crossed. Do I need to take the soft top off completely?
Complete Novice
Post by swoakes » Sun Feb 18, 2018 3:28 pm
I think you can fit the soft top frame fitted and fit the hard top but I wouldn't do this on track
AndyM
Complete Novice
Post by AndyM » Mon Feb 19, 2018 1:12 pm
Tow Points? Hopefully I wont need it, but after seeing some rather expensive Ferraris in the gravel at Prescott last year, its got me thinking?
There is a tow loop on the front, but I can't see anything obvious at the back? I am sure I read on here somewhere that someone did something behind their rear number plate but I cant find it now? I found a picture with a naked SS1 showing a beam across the back. Is this what people use?
http://www.danlockton.co.uk/rebel/image ... dged_3.jpg
Complete Novice
Post by swoakes » Mon Feb 19, 2018 1:17 pm
You need a rear tow point. I used the unthreaded hole on the diff to mount an aluminium loop that you can buy off the shelf. I then used a nylon lifting sling strap from that loop to a point just below the rear bumper held at that point with a nylon strap.
A picture paints a thousand words so I'll dig out the photo :wink:
Complete Novice
Post by swoakes » Mon Feb 19, 2018 1:22 pm
Take a look here for the loop I used. Skip forward to page 30 for fitting photos
viewtopic.php?f=20&t=16823&p=210925&hil ... nt#p210925
Benc
Has thanked: 36 times
Complete Novice
Post by Benc » Mon Feb 19, 2018 1:34 pm
You also need a loop of some kind on the front, one of these will do.. http://www.demon-tweeks.co.uk/Product.d ... lsrc=aw.ds
I removed the existing front tow eye, welded a plate with a hole in to take the bolt, then refitted with the strap, you can see on the picture here scroll to bottom page..http://scimitarweb.co.uk/sgwrs/viewtopi ... 4&start=75
Complete Novice
Post by swoakes » Mon Feb 19, 2018 1:43 pm
The existing front tow point is fine just needs to be marked
Benc
Complete Novice
Post by Benc » Mon Feb 19, 2018 1:52 pm
Ok ignore my post then but thought they had to be a certain size?
AndyM
Complete Novice
Post by AndyM » Mon Feb 19, 2018 2:17 pm
Thanks again.
AndyM
Complete Novice
Post by AndyM » Mon Feb 19, 2018 2:38 pm
Could one of these also work at the back around a section of chassis?
https://www.ebay.co.uk/itm/Motorsport-H ... 1438.l2649
Complete Novice
Post by swoakes » Mon Feb 19, 2018 2:45 pm
Not that I am aware off Ben. Most cars have a front tow point that is readily accessible. It just needs marking so the Marshalls can find it quickly should they need to
Complete Novice
Post by swoakes » Mon Feb 19, 2018 2:50 pm
The steelwork behind the rear bumper on an SS1 is pretty thin and would not take much of a pull to pull it out of shape. Some have beefed this up by inserting a section of steel to the chassis below the tank I think linking the two together. I took the view that this was lots more work than what I did which was easy and cheap to achieve even by an amateur like me :wink:
