Goodwood 6 October 2018
Moderators: scimjim, erikscimitardemon, Lukeyboy46, Roger Pennington, philhoward, nickkeyser
Has thanked: 139 times
Been thanked: 988 times
Post by scimjim » Mon Aug 27, 2018 10:09 pm
2018_24 Goodwood regs.pdf
(287.42 KiB) Downloaded 41 times
2018_24 Goodwood Sprint Entry Form.pdf
(119.44 KiB) Downloaded 37 times
Has thanked: 30 times
Been thanked: 38 times
Post by nickkeyser » Wed Sep 12, 2018 6:52 am
I’ve entered; anyone else?
Has thanked: 133 times
Been thanked: 77 times
Post by efi_sprintgte » Sat Oct 06, 2018 8:25 am
Good luck today Nick
Has thanked: 357 times
Been thanked: 297 times
Post by CNHSS1 » Sat Oct 06, 2018 10:22 am
Good luck Nick
Been thanked: 104 times
Post by swoakes » Sat Oct 06, 2018 11:00 am
Good luck Nick...keep it on the black stuff. The weather forecast is pants I think :(
Post by nickkeyser » Sat Oct 06, 2018 3:33 pm
The weather progressively got worse. I think I was fastest in practice! Everyone got a damp first run, then some people did a wet second run before it was abandoned.
Post by swoakes » Sat Oct 06, 2018 4:06 pm
Not again....
Has thanked: 250 times
Been thanked: 209 times
Post by Corky » Sat Oct 06, 2018 6:27 pm
I feel your pain.......
Sounds like you got your two practice and one timed run? Little compensation if none of it counts due to the abandonment though...
Post by scimjim » Sat Oct 06, 2018 6:51 pm
I saw a picture of a very dented MX5 or S2000 on Facebook?
Post by swoakes » Sat Oct 06, 2018 6:55 pm
Howard Barnards MX5 I think
Has thanked: 260 times
Been thanked: 127 times
Post by MikeyBikey » Sat Oct 06, 2018 7:32 pm
Well, steve cox has already got the narrative from today emailed out with points etc. He does refer to you Nick Keyser's pocket rocket :)
Post by swoakes » Sun Oct 07, 2018 7:05 pm
I see that there was only 1 practice and 2 timed runs....presumably based on the weather forecast :?:
Anyways Nick Keyser take the 25 as the only SSSC runner in attendance.
So the SSSC Championship hinges on the last event Castle Combe on 20th October. If Josh takes the 25 he wins the championship with max points, If Nick takes the 25 he wins the Championship on "head to head count back" (points even on max points). If anyone else takes the 25 Josh takes the championship as he already has max points before Combe and Nick doesn't.
Post by nickkeyser » Mon Oct 15, 2018 5:32 pm
A bit academic but records my best time was 113.81.
The incar from that run, inc a ‘moment’ at St Mary’s.
https://youtu.be/xej05jtMkWM
Has thanked: 149 times
Been thanked: 527 times
Post by Roger Pennington » Mon Oct 15, 2018 7:10 pm
Well held, Nick!
Sorry I wasn't able to be there to see you in action, but I had a prior commitment to a classic car run to Brooklands with Southern Classics - and that was wet too :roll:
Post by CNHSS1 » Mon Oct 15, 2018 8:16 pm
Blimey Nick! :shock: you caught that beautifully! 8)
Car looked balance even given the greasy conditions, cars well set up :clap:
