Abingdon
Moderators: scimjim, erikscimitardemon, Roger Pennington, Lukeyboy46, philhoward, nickkeyser
Abingdon
Post by scimjim » Mon Mar 05, 2018 11:36 am
http://www.on-track.co.uk/venue-abingdo ... eld-sprint#
http://www.motorsportcircuits.co.uk/htm ... guide.html
Abingdon circuit has an excellent mix of technical corners and long straights and as Abingdon is an airfield circuit it offers large run off areas for when you’ve pushed a little too much. Abingdon has very smooth tarmac and long straights so you can push your car to the very max knowing you have the large run off areas just in case you need them.
Return to “Venues”
