number plate lamps
Been thanked: 385 times
number plate lamps
Post by peter freeman » Tue May 14, 2019 8:36 pm
One of my number plate lamps failed so I bought a new pair ( Triumph ) only to find they use a BA9 bulb whereas the originals were T10. The LEDs for BA9 lamps holders are long and therefore touch the glass anyone know where I can get the same style lamp holders that use T10 lamps.
Has thanked: 189 times
Been thanked: 37 times
number plate lamps
Post by willholderogri » Tue May 14, 2019 9:29 pm
I bought a push bike led lamp looks good and was very cheap
Andrewsait
number plate lamps
Post by Andrewsait » Fri May 17, 2019 9:55 am
Will,
You could try these people:
www.bettercarlighting.co.uk
Put BA9 into the search box and it will show quite a large selection of different types. If in doubt e-mail them for a data sheet to see the actual physical size.
I have used their bulbs quite extensively on several cars and have found them very good. Also, they are very good at responding to e-mailed questions.
Andy
number plate lamps
Post by willholderogri » Fri May 17, 2019 12:07 pm
. This is mine works well looks neat and very little current
number plate lamps
Post by willholderogri » Fri May 17, 2019 12:22 pm
Has thanked: 155 times
Been thanked: 1052 times
number plate lamps
Post by scimjim » Fri May 17, 2019 12:55 pm
You can still buy metal ones with glass lenses if you prefer it to plastic Will.
I’m not sure what lights the Middlebridge has - are they just 6/6a/6b/GTC type?
number plate lamps
Post by peter freeman » Fri May 17, 2019 1:02 pm
I think they are the same as the 6's Jim but only seem to come with bA9 holders now whereas the originals had T10 bulbs and the BA9 LEDs are longer so they come into contact with the glass.
nummber palte lamps.jpg (26.41 KiB) Viewed 847 times
Return to “Middlebridge”
