Windscreen Wipers not parking.
Windscreen wipers work fine other than in my ownership have never self parked (I have to correctly time switching off the wipers for them to park at bottom of the screen). Before I get out the bag of spanners to sort it can anyone suggest what the cause might be?
- philhoward
- RSSOC Member
- Has thanked: 43 times
- Been thanked: 539 times
- Contact:
Usually the parking switch on the motor itself but double check you have the secondary supply.
Tony Idle did a wonderful article for Slice a few years ago which tells you everything you ever needed to know about wiper motors.
- PeteMac
- RSSOC Member
- Has thanked: 15 times
- Been thanked: 9 times
- Contact:
Possibly a number of threads on this topic - here's one I remember from a few years back.
1987 1800Ti
(previous 1975 SE5a, 1968 GT)
- peter freeman
- RSSOC Member
- Has thanked: 9 times
- Been thanked: 326 times
- Contact:
Power for parking I think is on the white/green wire - check you have power on this wire with the wipers off and the ignition on - otherwise as Phil says - and more likely - the parking switch on the motor ( socket ) is not working - could well be dirt in it.
