Fusebox
simmit
Has thanked: 121 times
Fusebox
Post by simmit » Fri Jun 23, 2017 11:07 pm
MB50 lost all instruments which turned out to poor fuse connection. Has anyone else had issues with the fusebox? Would it be wise change the old style box (glass fuses) for modern blade type? Don't want fire.
Re: Fusebox
Post by greeny » Sat Jun 24, 2017 7:54 am
Take the fuses out and clean the blades that hold the fuses, it makes a massive difference.
However I have a couple of blade type fuses that I am looking at the best one to fit.
Been thanked: 212 times
Re: Fusebox
Post by AJL Electronics » Sat Jun 24, 2017 9:02 am
Geoff Cooper made some conversion fuseboxes and I have one available if needed. I have gone with a different solution so surplus to requirements. It is fully built with six inch tails prewired. You will need to enlarge the hole in the kickboard to take it though.
simmit
Re: Fusebox
Post by simmit » Sun Jun 25, 2017 11:38 am
AJL Electronics wrote:Geoff Cooper made some conversion fuseboxes and I have one available if needed. I have gone with a different solution so surplus to requirements. It is fully built with six inch tails prewired. You will need to enlarge the hole in the kickboard to take it though.
Will send PM.
Return to “Middlebridge”
