Location, ecu & service connector.
simmit
Has thanked: 121 times
Post by simmit » Mon Apr 17, 2017 6:34 pm
Where is MB ecu and it's service connector? Hiding behind a carpet/ panel somewhere?
Has thanked: 41 times
Been thanked: 210 times
Re: Location, ecu & service connector.
Post by AJL Electronics » Mon Apr 17, 2017 6:46 pm
Have a look in the passenger side behind the kick panel.
Been thanked: 319 times
Post by peter freeman » Mon Apr 17, 2017 7:42 pm
When you find your ecu you might look at the part number - my auto car had a manual ecu fitted which meant that when you lift off the throttle the car does not slow down - not that it slows much with the correct ecu fitted. I suspect that MB in true Reliant style just bought a box full of ecu's ( all the same ) and fitted them to all cars. The correct part numbers are:-
auto 86GB-12A650-BD manual 86GB-12A650-B2A
ecu's can be bought from
https://www.atpelectronics.co.uk/search ... mit=Search
I now have a auto ecu fitted and keep the manual one as a spare - it did work so not to be thrown away - cost for a new one was around £160 five years ago so not that expensive
Return to “Middlebridge”
