Fuel line connectors.
simmit
Has thanked: 117 times
Post by simmit » Mon Jul 25, 2016 9:58 pm
MB50 may be typical or not but it had two black plastic push on fuel connectors to the copper pipes. I had been changing the fuel hoses to meet latest fuel specification when I found these connectors (not knowing at first whether they were simply connectors or something technical to do with the fuel system). Anyway, having discovered they were simply connectors I assumed they must have sealing 'O' rings in them and perhaps the modern fuel might be affecting them so I removed the connectors (cut them off) and had them apart to check condition of the 'O' rings. They were hard and brittle and I'm glad they are now off the car as potential fuel leaks make me nervous.
Not suggesting there is a problem generally but thought it worth a mention here.
Been thanked: 483 times
Re: Fuel line connectors.
Post by philhoward » Mon Jul 25, 2016 10:03 pm
I'd be more worried about the use of Copper for fuel lines myself?
simmit
Post by simmit » Mon Jul 25, 2016 10:16 pm
philhoward wrote:I'd be more worried about the use of Copper for fuel lines myself?
Do you think copper may age harden and crack? What would be your alternative? What do they use on modern vehicles?
Post by philhoward » Mon Jul 25, 2016 10:21 pm
No "may" about it - it will crack if subject to the slightest vibration.
Nylon has been in use for nearly 50 years for fuel lines.
Been thanked: 197 times
Post by AJL Electronics » Mon Jul 25, 2016 10:25 pm
If you need rigid fuel line, then it has to be Kunifer.
Post by philhoward » Mon Jul 25, 2016 10:30 pm
Steel has been used for many years but I wouldn't choose it myself. If you need a rigid line, then Kunifer for sure. I find Nylon more than adequate personally, as do most vehicle manufacturers these days.
Post by toomanysabres » Tue Jul 26, 2016 12:19 am
I have used Kunifer (truck size brake pipe) for years.
simmit
Post by simmit » Tue Jul 26, 2016 2:13 pm
Did MB use copper or Kunifer (or what) in their builds? I said copper because the pipe has copper colouring but it may be Kunifer, you guys know better than I.
Post by AJL Electronics » Tue Jul 26, 2016 2:14 pm
Standard is nylon.
simmit
Post by simmit » Wed Jul 27, 2016 9:49 am
AJL Electronics wrote:Standard is nylon.
MB50 definitely not nylon. What grade nylon is specified for fuel lines and can you suggest source for tube and fittings (in particular, hose tail to rubber hose)?
Post by AJL Electronics » Wed Jul 27, 2016 10:38 am
If you are starting from scratch, then just go with 5/16" Kunifer. Flare the ends where it changes to rubber. Make sure it is well supported, even though it is not as bad as copper, you don't want bits vibrating.
simmit
Post by simmit » Wed Jul 27, 2016 3:40 pm
AJL Electronics wrote:If you are starting from scratch, then just go with 5/16" Kunifer. Flare the ends where it changes to rubber. Make sure it is well supported, even though it is not as bad as copper, you don't want bits vibrating.
Thanks.
Has thanked: 17 times
Been thanked: 20 times
Post by nickkeyser » Wed Jul 27, 2016 6:42 pm
What about aluminium? Seems the most common in the aftermarket.
Return to “Middlebridge”
