Plug gaps
Has thanked: 229 times
Been thanked: 112 times
Plug gaps
Post by MikeyBikey » Wed Jul 18, 2018 7:42 am
Blimey.
Lots of short runs ? Leaving unburnt fuel on the plug ?
Has thanked: 50 times
Been thanked: 591 times
Plug gaps
Post by philhoward » Wed Jul 18, 2018 7:48 am
I've heard of some "valve protection" additives leaving deposits on the plugs but can't remember which one it was :oops:
Been thanked: 347 times
Plug gaps
Post by peter freeman » Wed Jul 18, 2018 8:44 am
That looks more like water been at them.
Been thanked: 47 times
Plug gaps
Post by Old and Slow » Wed Jul 18, 2018 9:29 pm
A clear case of oil fouling, if you believe this chart, which some don't.
Plug gaps
Post by Old and Slow » Thu Jul 19, 2018 8:29 pm
Is it a high mileage engine? If so then IMO could be either valve guide seals or worn rings/bores.
I think I'd start with a dry compression test, and then add a tiny amount of oil to each cylinder in turn and repeat the compression test. If there's a 20% or more improvement when wet then I think that means it needs new rings (but someone with more experience could advise what change to expect).
Otherwise replace the valve guide stem seals?
If it is a result of mostly short trips then try a good run out and see if the oily carbon can be burned off.
Good luck.
RonH
Plug gaps
Post by RonH » Thu Jul 19, 2018 9:24 pm
Cheers old and slow. 77,000 miles. 300 miles last year :oops: 5000 since 2011. Now the iridium plugs are fitted I’ll give the car a good run and check one of the plugs (that is apart from number 1 what a pain). I could possibly pick out a colour match for many of the oil fouled plugs and many other pictures. All except the light straw which is what I had hoped for. Valve guide seals is high on my list of suspects.
Ron (custodian of GTC 404)
Return to “Middlebridge”
