Plug gaps
Been thanked: 419 times
Plug gaps
Post by peter freeman » Tue Feb 17, 2015 8:38 pm
Planning to replace the plugs just before the MOT ( first time I have done it on this engine ). I think the plugs are BCPR7ES but cannot find the info in the Haynes manual nor can I find any info re the gap which I assume is either 25 or 30 thou - can someone please confirm.
Has thanked: 167 times
Been thanked: 1177 times
Re: Plug gaps
Post by scimjim » Tue Feb 17, 2015 8:54 pm
it's in the "specifications" at the end of chapter one (maintenance) in the new fangled layout but not referenced anywhere (the index for example :roll:)
Champion RCY9CC or equivelant (NGK go the opposite way on heat rating IIRC) - 0.8mm gap.
Re: Plug gaps
Post by peter freeman » Tue Feb 17, 2015 8:56 pm
0.8mm - when will they realise we are British. Cheers Jim.
Re: Plug gaps
Post by scimjim » Tue Feb 17, 2015 8:57 pm
BCPR6ES according to this cross-ref site?
Re: Plug gaps
peter freeman wrote:0.8mm - when will they realise we are British. Cheers Jim.
yes, you'd think Haynes would know better :-)
Re: Plug gaps
Post by peter freeman » Tue Feb 17, 2015 9:09 pm
6ES - 7ES are fitted at the moment.
Re: Plug gaps
Post by peter freeman » Tue Feb 17, 2015 9:36 pm
Jim just looked at the manual page you quoted and its a 6ES for the cars with a cat fitted 7ES for cars without cats.
Re: Plug gaps
Post by scimjim » Tue Feb 17, 2015 9:57 pm
my manual (OWM1245 of 1999 vintage) only has Champion numbers - RC9YCC for non-cat, RS9YCC for cats.
Re: Plug gaps
Post by peter freeman » Tue Feb 17, 2015 10:19 pm
Yes only champion quoted but RC7YCC for non cats and RC9YCC for cats - I looked up the NGK equivalents on the website you had the link to. My manual is for Granada & Scorpio March 1985 to 1994 - Haynes 1245.
Re: Plug gaps
Post by scimjim » Tue Feb 17, 2015 11:38 pm
hmm - mine (dated 1999 on first page) doesn't mention a RC7YCC but says:
RF7YCC for 1.8/2.0
RC9YCC for 2.0 DOHC
RN9YCC for 2.8 V6
RC9YCC for 2.4/2.9 without cat
RS9YCC for 2.9 with cat
all 0.8mm gap
Re: Plug gaps
Post by peter freeman » Wed Feb 18, 2015 9:17 am
My book is from 1998 so they have changed things but why ?
*JP*
Has thanked: 17 times
Re: Plug gaps
Post by *JP* » Wed Feb 18, 2015 11:24 am
Re: Plug gaps
Post by peter freeman » Wed Feb 18, 2015 12:10 pm
I have had a plug out and the end is tapered - perhaps the heads were modified for a flat plug after my engine was built.
Re: Plug gaps
Post by scimjim » Wed Feb 18, 2015 12:35 pm
According to my manual there are 3 different heads for the 2.9 (same blocks all with F casting):
BRC - non-cat (F cast into head) - 9.5:1 compression, 110Kw @5700rpm/233Nm @ 3000rpm
BRD - type 9 or auto with cat (K cast into head) - 9:1 compression, 107Kw@5500rpm/222Nm @ 3000rpm
BRE - MT75 with cat (K cast into head) - 9:1 compression, 107Kw@5500rpm/226Nm @3000rpm
2.8 is PRE with E block casting and EN head casting
2.4 is ARC wth D block casting/H head casting
from the PH link above "AFAIK, the "K" means taper seats, "F" means flat seats"
of course, you have to wonder what Ford (presumably Ford Power - possibly still through Reliant?) provided MB with? :-)
Has thanked: 106 times
Been thanked: 807 times
Re: Plug gaps
Post by philhoward » Wed Feb 18, 2015 12:42 pm
Indeed - never assume it's a "Granada" engine - could well be the same setup supplied to TVR which could have been some generic version, or just an "aftermarket" spec specifically for use by Ford (Industrial) Power (Products)/Racing/whichever name that arm had at the time. Look at the CVH they supplied for the SS1 - I think it's only presumed it was a German Sierra version, unless anyone knows different.
Return to “Middlebridge”
