Who says tractor engineering is agricultural
Moderators: scimjim, philhoward, Lukeyboy46, erikscimitardemon, Roger Pennington, Terry Rickard
TrevorG
Has thanked: 17 times
Been thanked: 20 times
Post by TrevorG » Tue Jun 11, 2019 4:59 pm
Just spent a fair bit of today renovating a 1956 international tractor brakes and thought it worth a mention that here is an agri vehicle with in-board disk brakes. Made me wonder why the car industry didn't catch onto this earlier? Admittedly, they are operated by concentric steel plates with ball bearings running in grooves, but the simplicity of dismantling without major surgery is to be congratulated. Also, there are two double sided circular friction plates on each side, so the stopping power is massive (when friction material renewed!).
Has thanked: 136 times
Been thanked: 967 times
Post by scimjim » Tue Jun 11, 2019 5:09 pm
Jag had inboard discs in the 60s didn’t they? And the Rover P6 in the mid 60s. Racecars had them earlier I think, to reduce unstrung weight.
The Citroen SM has them on the front!!!
Been thanked: 617 times
Post by philhoward » Tue Jun 11, 2019 5:39 pm
Jags had inboard rear discs on everything with IRS until the facelift XJS in the early 90’s but the P6 had it since introduction in 62-ish?
Even a 2CV has inboard front discs..
Has thanked: 342 times
Been thanked: 279 times
Post by CNHSS1 » Tue Jun 11, 2019 5:50 pm
Inboard discs put braking thrust loads into diff and transmissions, even on race cars with trans axles (Hewland boxes etc). Also outboard generally easier to cool.
A guy fitted inboard discs to a Sierra diff ( dead easy to do actually) but heat cooled diff bearings and oil so needed oil cooler and regular rebuilds.
Also on a car with reasonable power and weight, it does funny things under braking as the discs are braked but then theres the tolerance for the CV or UJ joints meaning you end with a lead and lag braking across the axle
Always liked the idea of trying on an ss1 but the rubber mounted diff would be an issue
drcdb15
Has thanked: 29 times
Been thanked: 26 times
Post by drcdb15 » Tue Jun 11, 2019 6:02 pm
Quite apart from practical issues such as line of sight for inspection and proximity to the outside for ease of access and maintenance, aren't there some theoretical reasons why in board brakes may not be such a good idea - such as if anything in the transmisson downstream of the brakes fails then the brakes may not stop the runaway vehicle which rather bypasses the primary objective. As I recall, weren't there truck brakes once that clamped curved brake shoes around the centre of the driveshaft to the rear wheels? Which was fine provided the diff etc held against the momentum of the vehicle. Not sure in the 40s and 50s that the materials were necessarily to be relied upon. If the aim is not so much to stop the vehicle as to stop the wheels from turning, then the closer you get to the wheel itself the better. Mind, I doubt this sort of argument applies to your typical tractor!
Chris
Has thanked: 144 times
Been thanked: 525 times
Post by Roger Pennington » Tue Jun 11, 2019 6:08 pm
On "normal" road cars I think one of the big downsides with inboard discs has always been access and visibility, for routine maintenance? Tractors share with racecars, minimal bodywork and exposed internals, making access to things like inboard brakes much easier.
TrevorG
Post by TrevorG » Tue Jun 11, 2019 6:31 pm
Sorry, shouldn't have overdone the in-board bit. My real emphasis was that tractors had disc brakes mid 50s!
Post by scimjim » Tue Jun 11, 2019 6:35 pm
1902 Lanchester? I think it was mainly aircraft only until the Jaguar C-types in the 50s
drcdb15
Post by drcdb15 » Tue Jun 11, 2019 7:33 pm
... exposed internals ...
Isn't that an oxymoron ? :) :w
Chris
drcdb15
Post by drcdb15 » Tue Jun 11, 2019 7:36 pm
I can never quite get my head around the fact that Lamborghini make tractors, and have done since 1948. Now I'm not surprised *they* had disc brakes ! :lol:
Chris
MickP
Post by MickP » Tue Jun 11, 2019 7:49 pm
I sat my first driving test in a Lamborghini when I was aged 16 (a tractor, obviously :lol: ).
SOLD: 1978 SE6a Auto.
1960 BSA Bantam D7 - more "fun" than the Ducati.
Gallery Project
Return to “Other Car Chat”
