ABS sensors
Has thanked: 50 times
Been thanked: 258 times
ABS sensors
Post by AJL Electronics » Wed Jun 14, 2017 8:20 am
Ford Scorpio 1996 estate with ABS failure. Code read suggsts rear offside ABS sensor. Unfortunately, the sensors appear to be completely unavailable. I haven't yet checked its resistance because the connector is buried in the interior, but assuming it is dead, what do I do?
As ABS sensors are simple devices. I would have thought that they were all electronically similar, being only the mounting method and cable length that varied. So, if for instance a front one fitted the space, could I just join it back to the longer wiring to that position and expect it to work?
Has thanked: 77 times
Been thanked: 704 times
Re: ABS sensors
Post by philhoward » Wed Jun 14, 2017 8:24 am
As long as its mechanical fitting is the same then it should be fine. From memory it's a flexible shielded cable so you should be able to figure out a suitable jointing method.
Re: ABS sensors
Post by philhoward » Wed Jun 14, 2017 8:29 am
Pick one from a vehicle with the same version of ABS though - response and resistance values differ between them.
Resistance check to confirm sensor and cabling first though as it could equally be a build up of muck in the toothed ring.
Has thanked: 153 times
Been thanked: 1050 times
Re: ABS sensors
Post by scimjim » Wed Jun 14, 2017 8:32 am
yep - first check is a wire brush on the hub reluctor ring.
Return to “Other Car Chat”
