Bad design !
Has thanked: 138 times
Been thanked: 149 times
Re: Bad design !
Post by Corky » Fri Feb 24, 2017 8:40 am
philhoward wrote:2 reasons for the price of one IMHO
............ and they are ?
(At a guess)
The garage over estimates the time it will take so they don't lose out?
They use expensive non pattern parts to cover themselves?
Been thanked: 534 times
Re: Bad design !
Post by philhoward » Fri Feb 24, 2017 8:50 am
Sorry - reply was to Roger!
Turning the engine 2 revolutions both seats the belt and checks you don't have valve to piston interference.
Been thanked: 460 times
Re: Bad design !
Post by Roger Pennington » Fri Feb 24, 2017 12:15 pm
That's true Phil, though I'd suggest there's a fundamental difference - if the job's been done properly, there shouldn't be any possibility of valve/piston contact, but no matter how well or badly the job has been done, you will *always* have to settle the belts before checking the tension. So I'd say the first check is the essential, the second is just a "peace of mind" thing to settle any doubts :)
Barrie James
Been thanked: 8 times
Re: Bad design !
Post by Barrie James » Sun Feb 26, 2017 7:43 pm
In a properly designed engine: are there any? The camshaft would be shaft driven from the crankshaft.
How about this for an idea. Horizontally opposed, six cylinder 2.5Ltr, air cooled. Twin contra rotating crankshafts, two con-rods per piston, shaft driven single overhead camshafts. Would cost a mint, but last forever.
Barrie.
2000 MGF Wedgwood SE
2002 Peugeot Partner 1400
RSSOC 2778
Been thanked: 86 times
Re: Bad design !
Post by Coupe Racing » Sun Feb 26, 2017 8:05 pm
Who needs camshafts when you can have hydraulic activated valves
Re: Bad design !
Post by Roger Pennington » Sun Feb 26, 2017 8:12 pm
Four cylinder Vintage Bentleys (3 & 4.5 litre) had a shaft driven overhead camshaft.
In the case of the six cylinder cars (6.5 and 8 litre) they had a different system - the three-throw drive. Basically, driven off the nose of the crank, was a small crankshaft with three journals at 120 degrees. The camshaft had a similar short crankshaft on the end, and they were linked by three connecting rods, running up the height of the engine, which transmitted the drive. :D
Been thanked: 840 times
Re: Bad design !
Post by scimjim » Sun Feb 26, 2017 8:22 pm
Are there any engines with electrically actuated valves yet? Solenoids won't sap engine power :-)
Re: Bad design !
Post by scimjim » Sun Feb 26, 2017 8:27 pm
Barrie James wrote:In a properly designed engine: are there any? The camshaft would be shaft driven from the crankshaft.
I'm not sure why shaft driven would be any more "proper" (efficient, cheaper, quieter?) than belt, chain or gear driven? I'm also having problems visualising contra-rotating cranks (do you mean counter-rotating?)
Return to “Other Car Chat”
