Volvo XC90 related
speedy555
Has thanked: 77 times
Been thanked: 35 times
Volvo XC90 related
Post by speedy555 » Mon Jan 09, 2017 8:38 pm
So, ive had my late 2007 xc90 for a week, it had 10 months MOT and had done 500 miles since its MOT, and I got it from a small garage.
Anyway, when you brake at speed, even under very light braking it dives to the right (doesn't so much pull, just dives to the right) and then goes back left when you release the pedal. It was OK when I test drove it, but maybe coincidentally it had a whopping 47psi in the right front tyre and 29 in the left (Should be approx. 35) and the pulling issue only came to light after setting the pressures correctly :| Ive since had the callipers off and greased the slide pins and may be fractionally better but is still unacceptable - Now I hope / presume the garage will sort it (Though not totally convinced as waiting to hear) but wondered if there were any suggestions as to its cause? Lower wishbone bushes sound next favourite to me??
Dave Speed
75 se5a 84 6b Triumph Gentry
Prev. 3x SS1/ 68 coupe/ 2x 6a / 9x 5a's /3x 6b's / Cipher / 3 x 69 se5 / rialto / Rochdale Olympic
5 series Registrar
www.ssgclassics.co.uk
www.facebook.com/ssgclassics
Has thanked: 529 times
Been thanked: 459 times
Re: Volvo XC90 related
Post by CNHSS1 » Mon Jan 09, 2017 8:59 pm
My Bro's last XC90 R design had creaking front bushes and the last time I drove it I swear it pulled a little but he traded it for a new one so it never got sorted or confirmed what it was. On of hi his the tracking was out a tiny bit and with huge tyres it did magnify the effects, but I still think wishbone bushes are favourite
Post by CNHSS1 » Mon Jan 09, 2017 9:01 pm
Also worth checking tyre pressures and defo tyre tread depth, the rolling radius across an axle does make a noticeable difference. Rich knackered a tyre (bolt thro the wall) a week before his new one arrived and he had to swap the new one to the rear as it was like a shopping trolley with a wonky wheel as the new tyre was about 10mm bigger than the other low tread ones
Post by CNHSS1 » Mon Jan 09, 2017 9:02 pm
Oops didn't read ya tyre pressure bit properly
speedy555
Post by speedy555 » Mon Jan 09, 2017 9:13 pm
Cheers. Tyres are Pirelli Scorpions, 500 miles old. Thinking the wild pressures were to disguise the issue.....??
Dave Speed
5 series Registrar
Has thanked: 100 times
Been thanked: 802 times
Post by philhoward » Mon Jan 09, 2017 9:20 pm
At least buying it from a business you have comeback..
speedy555
Post by speedy555 » Mon Jan 09, 2017 9:23 pm
Yes, that's why I paid a premium. Don't trust them though TBH.....Didn't service it right, claimed they tried to track the towball down and hadn't done, and now possibly trying to hide this issue....its generally a very nice car but things like this that should be right are a pain in the rear.
Dave Speed
5 series Registrar
Post by greeny » Mon Jan 09, 2017 9:52 pm
You can't half pick them speedy!!
speedy555
Post by speedy555 » Mon Jan 09, 2017 10:05 pm
greeny wrote:You can't half pick them speedy!!
I know - if I buy for the wife or someone they are mint, but ive had a run of it :)
2003 sorento 105k, bought in 2015 and had 12 months.....discs, pads, fuel tank, fuel lines, fuel pump, filter housing, 2x intercoolers, battery, tyres, gearbox fault, 4x injectors, rear shockers.
2008 sorento, 61k FSH, bought 2016 had for 10 months.....timing chain, auto box, oil pump, turbo, rear shocks, springs, 2x injectors, tyres, battery, 4x discs, starter.
Without road tax (500 p/a) and fuel, but with depreciation / loss / servicing and repairs they coast approx. £300 pcm to run them over the period :shock: :cry:
Im hoping for 3rd time lucky.......
Dave Speed
5 series Registrar
Has thanked: 31 times
Been thanked: 125 times
Post by Coupe Racing » Thu Jan 12, 2017 7:11 pm
Sounds like sliding calipers - and one has a sticky piston - my BMW did the same
I could push the piston back into the bore - but was stiff - more so than the other side.
Has thanked: 33 times
Been thanked: 51 times
Post by Alan SS1 » Thu Jan 12, 2017 7:20 pm
not sure what the floor pan on the big Volvo is from but the C30 shares it with the FOCUS,
what sort of front control arms/wishbone's are they? (bolt through front and clamp at rear ?). my C30's front control arm REAR bushes were so far shot (after 40k) it was scary when I removed them and gave a good 'wiggle' in the vice, more 'void' than bush. :shock: the arms can't escape but maybe one old arm, one new arm so giving a change to steering geometry under braking (if not the calipers)
speedy555
Post by speedy555 » Thu Jan 12, 2017 7:28 pm
I think the XC90 chassis is basically the V70 estate. I've greased all the calliper sliders now, and its going to my local garage tomorrow for investigation - hopefully its obvious, they will do it and the garage I got it from have agreed to foot the bill. I couldn't find anything on the bushes, but hopefully the garage will!
Dave Speed
5 series Registrar
erikscimitardemon
Been thanked: 21 times
Post by erikscimitardemon » Thu Jan 12, 2017 7:58 pm
Ouch!
So I can't complain in my E750.- Saab 93 of 2000 vintage. 425K km on the clock. This week it got a new APK (MOT eq.). All it needed was a handbrake adjustment. :D
Erik Hofman
http://www.scimitar.demon.nl
Has thanked: 353 times
Been thanked: 170 times
Post by MikeyBikey » Thu Jan 12, 2017 8:14 pm
Sorry to hear the woes speedy. I've paid £470 for an 02 focus. Hated it initially but it's brilliant. 12000 miles later in 6months. I've spent £60 on 2 tyres. 45 mpg. Goes very well and everything works.
speedy555
Post by speedy555 » Thu Jan 12, 2017 8:19 pm
I had my Transit for 8 years previously without an issue - Just unlucky with 2, and hopefully once the current issue is sorted the Volvo will be fine :)
Dave Speed
5 series Registrar
Return to “Other Car Chat”
